Call it a brain fade, but I haven't used LT in a while, and I need to help one of my remote users. Once you place a block with an attribute, how do you rotate the attribute?
eattedit is not an available command in LT, because it is a lisp file correct?
attedit is available in LT98, and I am assuming later versions. That will allow you to change the rotation of attribute text
I wish that was true. attedit allows me to edit the content of the attribute, however it does not allow me to change the properties (txt height, rotation, etc....)
HiOriginally Posted by darin.marsden
The command ._EAttEdit has been available within AutoCAD since 2000i, from the first Technical Document that Michael gave you it looks like ._EAttEdit only just made in into AutoCAD LT (2005).
Have a good one, Mike
ps Sorry I can't help you anymore on this (I've never used AutoCAD LT)
From the help file:Originally Posted by darin.marsden
If you enter -attedit at the Command prompt, ATTEDIT displays prompts on the command line.
Edit attributes one at a time? [Yes/No] <Y>: Enter y or press ENTER to edit attributes one at a time, or enter n to edit attributes globally
Yes
Edits attributes one at a time. Attributes to be edited one at a time must be visible and parallel to the current UCS.
Enter block name specification <*>: Press ENTER, or enter a block name or a partial block name with wild-card characters (? or *) to narrow the selection to specific blocks
Enter attribute tag specification <*>: Press ENTER, or enter a tag or a partial tag with wild-card characters (? or *) to narrow the selection to specific attributes
Enter attribute value specification <*>: Press ENTER, or specify a value or a value name with wild-card characters (? or *) to narrow the selection to specific attribute values
Attribute values are case sensitive.
Select Attributes: Select only attributes parallel to the current UCS
AutoCAD marks the first attribute in the selection set with an X. You can change any properties of the attribute you select.
Enter an option [Value/Position/Height/Angle/Style/Layer/Color/Next] <N>: Enter the property to change, or press ENTER for the next attribute
If the original attribute was defined with aligned or fit text, the prompt does not include Angle. The Height option is omitted for aligned text. For each of the options, except Next, AutoCAD prompts for a new value. The X remains on the current attribute until you move to the next attribute.
Hi
Hold the press batman....
Can you use the command line version of AttEdit in AutoCAD LT? If yes, it will do what you want -
CommandLine: ._-AttEdit
Select Attributes: 1 found
Select Attributes:
1 attributes selected.
Enter an option [Value/Position/Height/Angle/Style/Layer/Color/Next] <N>: _Angle
Specify new rotation angle <0.0000>:
I appreciate all the replies, however nothing is working. I read the same thing that _eattedit was associated with AutoCAD LT 2005, however it does not work.
There has got to be a way. Help Autodesk!!!!!!!!!
Hi
I take it that the command line version of ._-AttEdit does not work in AutoCAD LT?
ps Would be nice if some actual AutoCAD LT users put their shiny penny's worth in....
