Results 1 to 9 of 9
Thread: Error when loading LSP file - error: bad argument type: fixnump: nil
    2005-06
    Idaho, USA
    184
    Default Error when loading LSP file - error: bad argument type: fixnump: nil
    I am at a complete loss.. I got an error message when i loaded my .lsp file.
    What is this???????
    I have a lot of functions defined and setq's above all this, but I believe this is where things are having problems.
     ;load dialog box
      (setq DCL_ID(load_dialog "plat-test.dcl"))
       (if(not(new_dialog "Plat" DCL_ID))(exit))
      ;start dialog box
      (start_dialog)
    ;if cancel button pressed
      (action_tile "cancel" "(setq diag1)(done_dialog)")
      (action_tile "accept" "(setq diag2)(saveVars)(done_dialog)")
    (SETQ OLDSNAP(GETVAR "OSMODE"))
    (SETVAR "CMDECHO" 0
            "OSMODE" 0)
    ;setup for layout tabs
    ;number of layout tabs needed
    (SETQ S1 (getint "\nHow many sheets? (do not include signature sheets)"))
    ;entering loop for layout tabs
    (repeat (s1)(command "._layout" "_n" """")))
    (unload_dialog DCL_ID)(princ))
    AUGI Addict kennet.sjoberg's Avatar
    2002-05
    1,707
    Default Re: Error when loading LSP file - error: bad argument type: fixnump: nil
    (s1) <-- this is how to call and run a function
    remove the paranthesis to use the value inside S1
    : ) Happy Computing !
    kennet
    2005-06
    Idaho, USA
    184
    Quote Originally Posted by kennet.sjoberg
    kennet
    Sorry but it didn't work.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,105
    Quote Originally Posted by eleonard
    Did you remove the parenthesis from around the s1 variable?
    (repeat s1(command "._layout" "_n" """")))
    2005-12
    2
    Quote Originally Posted by Opie
    there is still an extra right parenthesis...
    otherwise seems ok
    Earth
    9,805
    Quote Originally Posted by gyula_58
    otherwise seems ok
    Have you loaded and ran your code in VLIDE? If so, check the "error trace". This will tell you exactly where the error is occuring.
    R.K. McSwain | CAD Panacea |
    2002-05
    1,707
    otherwise seems ok
    Welcome to the forum, eagle eye
    kennet
    2003-11
    277
    Hi eleonard,
    Your code should change,like this
    ;--------------<snip>---------------------
    (repeat
      s1                              ; change from (s1) to s1
    )                                  ; remove this close parentheis
    What is this???????
     ;load dialog box
      ;start dialog box
      (start_dialog)
    (SETVAR "CMDECHO" 0
            "OSMODE" 0)
    2005-06
    Idaho, USA
    184
    Thanks I will give that a try. I quit working on it yesterday after I got such a headache I couldn't even think.
  1. Error: bad argument type: FILE "r"
    By shell2712 in forum AutoLISP
    Last Post: 2013-09-04, 08:29 PM
  2. error: bad argument type: numberp: nil
    By U.Rackharrow in forum AutoLISP
    Last Post: 2010-03-05, 01:01 PM
  3. Replies: 4
    Last Post: 2009-05-22, 05:21 AM
  4. Autolisp error bad argument type: fixnump: nil
    By arubus1977 in forum AutoCAD Customization
    Last Post: 2009-05-13, 03:09 PM
  5. Replies: 3
    Last Post: 2006-12-11, 08:31 PM
