Results 1 to 8 of 8
Thread: Importing, onto sheets, JPEG's made from Revit Views
    2003-05
    East Walpole, MA
    893
    Default Importing, onto sheets, JPEG's made from Revit Views
    I sometimes try to export a 3D view from one file, then import that image onto the sheet of another file. The results are always bad (very low resolution and weak colors). I've tried the different JPEG options and high res, but it makes no difference.
    Note: I never have a problem importing photos; it's only Revit exported images.
    Anyone know a work-around?
    AUGI Addict luigi's Avatar
    2015-11
    Royal oak, Michigan
    1,513
    Default Re: Importing, onto sheets, JPEG's made from Revit Views
    exporting any kind of image at any resolution is just impossible!!!!! the quality is worse than worse. It doesn't matter if it is a 300dpi of a 24"x36" exported to 3600x2400 pixel image (jpg,tiff, bmp, etc.) just unacceptable.
    I print to pdf then convert to image (but you need acrobat writer, or similar software)
    Ignore this part I have written below...I had a brain fart at the time.....this statement below is only possible for rendered images (you can't capture anything but a rendered image)... If you are printing from Revit, and my solution doesn't work for you due to software availability, then you can capture the image into a rendering view from within revit, and include that on a sheet.....it does of course add file size....
    Ciao!
    Quote Originally Posted by narlee
    2005-07
    3,250
    Yep, I wish you could write a decent jpg or png from a shaded view, but the quality is bad. The only solution is writing to pdf and using Photoshop to turn it to a jpg.
    AUGI Addict truevis's Avatar
    2004-07
    Massachusetts, USA
    1,191
    Found this one:
    http://www.nedatacorp.com/
    A freeware printer driver that makes TIFFs. Makes 9000+px wide at A3 size, 600dpi.
    Not bad, please try.
    2015-11
    Royal oak, Michigan
    1,513
    It's better...but AntiAliasing for diagonal lines is still missing...
    Quote Originally Posted by truevis
    Found this one:
    A freeware printer driver that makes TIFFs. Not bad, please try.
    2004-07
    Massachusetts, USA
    1,191
    Quote Originally Posted by luigi
    That's a blow up. The original TIFF is 200Mb. Here is a reduced JPG.
    2003-05
    East Walpole, MA
    893
    Great ideas! Thanks!
    2015-11
    Royal oak, Michigan
    1,513
    Looks Good!
  1. 2011: Revit crashes when placing views on sheets
    By Rosie the Reviter in forum Revit Architecture - General
    Last Post: 2016-12-15, 09:01 PM
  2. Combining Revit files (views and sheets)
    By cchallis in forum Revit - Platform
    Last Post: 2012-02-28, 07:55 PM
  3. AutoCAD LT 2006 - importing JPEG's
    By bob.kalsi66006 in forum AutoCAD LT - General
    Last Post: 2006-08-09, 12:33 PM
  4. Scaling an importing .jpeg file
    By walterk5384 in forum Revit Architecture - General
    Last Post: 2005-10-05, 03:16 PM
  5. Revit 8 -Importing Ordnance Sheets
    By cceng in forum Revit Architecture - General
    Last Post: 2005-05-01, 05:26 PM
