Thread: Invalid registered-application name and No matching xref names found yet they exist.
    2006-02
    19
    Default Invalid registered-application name and No matching xref names found yet they exist.
    Invalid registered-application name and No matching xref names found yet they exist. I'm looking at the xref right now. its in the drawing. I'm trying to detach it since I do not need it anymore.
    Command: TOOLPALETTES
    Command:
    No matching xref names found.
    Command: AUDIT
    Fix any errors detected? [Yes/No] <N>: Y
    Auditing Header
    Auditing Tables
    Auditing Entities Pass 1
    Pass 1 353000 objects audited
    Invalid registered-application name "" found.
    Changed to "AUDIT_I_070108095009-0".
    Pass 1 353700 objects audited
    Auditing Entities Pass 2
    Pass 2 353700 objects audited
    Auditing Blocks
    25 Blocks audited
    Total errors found 1 fixed 1
    Erased 0 objects
    Command: PURGE
    Command:
    I'm running Autocad Civil 3D 2007
    System Information
    Time of this report: 1/8/2007, 10:01:09
    Machine name:
    Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp.050622-1524)
    Language: English (Regional Setting: English)
    System Manufacturer: Dell Inc.
    System Model: Precision WorkStation 380
    BIOS: Phoenix ROM BIOS PLUS Version 1.10 A07
    Processor: Intel(R) Pentium(R) D CPU 2.80GHz (2 CPUs)
    Memory: 2046MB RAM
    Page File: 1215MB used, 2722MB available
    Windows Dir: C:\WINDOWS
    DirectX Version: DirectX 9.0c (4.09.0000.0904)
    DX Setup Parameters: Not found
    DxDiag Version: 5.03.2600.2180 32bit Unicode
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    2,020
    Default Re: Invalid registered-application name and No matching xref names found yet they exist.
    When you list the xref you see on the screen is it really an external reference or just a block reference? I was wondering if someone may have bound it to the drawing.
    Is the xref listed in the external reference manager?
    2006-02
    19
    It really is an Xref
    Civil Engineering Moderator civil3Dguide's Avatar
    2006-01
    Temecula, CA
    281
    In the xref manager it is not listed?
  1. Invalid registered-application name
    By s_howard in forum AutoCAD General
    Last Post: 2007-11-15, 05:12 PM
  2. copy an lman from an xref into another no matching layer names
    By Hammer.John.J in forum AutoCAD Tips & Tricks
    Last Post: 2006-09-16, 08:07 AM
  3. Registered Application lisp
    By t4duzan in forum AutoLISP
    Last Post: 2005-12-01, 09:02 PM
  4. Invalid Registered Application
    By martyk in forum AutoCAD General
    Last Post: 2004-10-12, 08:02 PM
