Thread: copy text entity values
    2006-04
    466
    Default copy text entity values
    ; this autolisp program copy text entity values.
    (defun c:tce()
        (prompt "\n Change text of selected object(s) to match entity\n")
        (setq
            loop
                T
        (while loop
            (if
                (setq
                    ent_to_change
                        (entsel "\nSelect text to change: ")
                (progn
                    (setq
                        ent_to_change
                            (entget
                                (car ent_to_change)
                        loop
                            (not
                               (OR
                                (eq
                                    (dxf 0 ent_to_change)
                                     "TEXT"
                                (eq
                                     "MTEXT"
                               );END OR
                    (entupd
                        (dxf -1 ent_to_change)
            (if loop
                (alert "Object selected was not text")
        (setq
            loop
                T
        (while loop
            (if
                (setq
                    ent_to_match
                        (entsel "\nSelect text to match: ")
                (progn
                    (setq
                        ent_to_match
                            (entget
                                (car ent_to_match)
                        loop
                            (not
                               (OR
                                (eq
                                    (dxf 0 ent_to_match)
                                    "TEXT"
                                (eq
                                     "MTEXT"
                               );END OR
            (if loop
        (setq
            text_to_change
                (dxf 1 ent_to_change)
            text_to_match
                (dxf 1 ent_to_match)
            old
                (assoc 1 ent_to_change)
            new
                (cons 1 text_to_match)
            ent_to_change
                (subst new old ent_to_change)
        (entmod ent_to_change)
        (princ)
    [ Moderator Action = ON ] What are [ CODE ] tags... [ Moderator Action = OFF ]
    I could stop if I wanted to kpblc2000's Avatar
    2006-09
    212
    Default Re: copy text entity values
    Why variables like ent_to_match, loop etc are not local?
  1. Replies: 0
    Last Post: 2013-06-20, 08:03 AM
  2. Replies: 4
    Last Post: 2008-11-13, 05:36 AM
  3. Replies: 21
    Last Post: 2006-10-18, 05:03 PM
  4. Extract Text and Text insertion point (X and Y values)
    By cscott.94049 in forum AutoCAD General
    Last Post: 2006-09-18, 06:02 PM
  5. How to get the width of a text entity?
    By GreyHippo in forum AutoLISP
    Last Post: 2006-05-25, 09:06 PM
