Results 1 to 6 of 6
Thread: My office uses ACAD I use ADT
    2004-06
    3
    Default My office uses ACAD I use ADT
    My entire office uses standard Autocad 2005, but do to some of the design work, and rendering that I do, I use ADT. A problem arises when I try to use the ADT callouts for a document that the rest of the office is going to use. Is there a way to load the standard Autocad Tool palettes so I can use the non-AEC-callouts. Or am I just crazy, and there is no difference.
    For example if I want to insert a section call out into a 2D drawing, I don't want to actually cut a 3D section, but I would like to use the full functionality of the fields that would reference the drawing in which the section is drawn. Please help. Thanks
    2001-10
    Arizona
    2,337
    Talking Re: My office uses ACAD I use ADT
    I would suggest that you investigate Enable Proxy graphics
    on save as so those regular CAD users will see the ARX objects you
    creat through ADT.
    Also investigate this it allow one to launch pure ACAD not ADT.
    http://usa.autodesk.com/adsk/servlet...linkID=2476059
    I quoted the above link because it pointed to 2000i products...the Correct link is shown below - RLB
    Use this link for ADT 2005:
    Be your Best,
    Michael Farrell
    www.primeservicesglobal.com
    Administrator richard.binning's Avatar
    2001-05
    In the foothills of the appalachians
    2,258
    Default Re: My office uses ACAD I use ADT
    If your office has standardized on AutoCAD 2005, then you should convince them to install the object enabler on all their PCs. Turn off the proxies, they just bloat your drawings more than necessary.
    The standard install of ADT 2005 has a "vanilla" profile and desktop shortcut built in if it was toggled on in the install. If not, then do a repair on your install.
    No matter what you do...certain commands will launch the ADT framework, so having your collaborators running the object enablers is really the best way to handle things.
    I could stop if I wanted to TroyGates's Avatar
    2003-07
    Irvine, CA
    277
    Is there an Architectural Object Enabler for AutoCAD 2005? I checked Autodesks website and found the following, but not Architectural Desktop Object Enabler...
    Autodesk Raster Design 2005 Object Enabler
    Autodesk Mechanical Desktop 2005 Object Enabler
    Autodesk Civil 3D 2005 Object Enabler
    Autodesk Land Desktop 2005 Object Enabler
    Autodesk Building Systems 2005 Object Enabler
    Here is the Link I got this from.
    2001-05
    2,258
    You don't need one. ADT and AutoCAD 2005 share common ground and the Object Enabler is integrated. I believe the other products underwent a file format change after the release of AutoCAD 2005 so they had to release object enablers. Check with the product page at autodesk.com for more info.
    2004-06
    waaaaay EAST of the 5
    172
    I must apologize as this question is unrelated to yours. I am in the process of upgrading to ADT '05. And will begin to offer renderings in addition to drafting, any suggestions?
  1. Office to office workflow, creating a local file
    By sfraney in forum Revit Architecture - General
    Last Post: 2009-01-21, 04:04 PM
  2. Acad 2009 (office)
    By spacedecor in forum AutoCAD Gallery
    Last Post: 2008-11-11, 04:40 PM
  3. Office CUI not loading acad.cui as adminstrator
    By ededios in forum AutoCAD CUI Menus
    Last Post: 2007-10-26, 09:49 PM
  4. Office ACAD.lsp file not loading for all users
    By Stephen.Walz in forum AutoCAD Customization
    Last Post: 2007-04-30, 03:32 PM
  5. Replies: 3
    Last Post: 2005-09-26, 08:35 PM
