Results 1 to 9 of 9
Thread: Can a PDF be opened and inserted into AutoCAD
    2005-06
    45
    Unhappy Can a PDF be opened and inserted into AutoCAD
    I can't find this issue in help menu. I thought I could insert a pdf as an OLE object. I was wrong. Or maybe someone knows how I can convert a PDF to another format that CAN be inserted ????
    Default Re: Can a PDF be opened and inserted into AutoCAD
    One thing you could do would be to convert the pdf to a jpeg or tiff image file with Photoshop or a similarly capable program. I'm not quite up to date on A2k7's pdf capabilities....maybe there is a new and improved way since A2k5.
    If your pdf document is a multi-paged document, this method may quickly frustrate you because you have to do each page individually.
    2003-10
    United Kingdom
    50
    which version of cad are you using? becoz I use autocad2007 and under the insert menu and on the OLE object, I could easily insert a pdf onto the drawing.
    2005-06
    45
    I am using AutoCAD 2006. Is PDF listed in your drop down when inserting OLE? It is not listed in mine.
    Turlock, CA
    6,409
    Use the 'create from file' option. The thing to remember about pdf is that they are like zip files, i.e. they are compressed and hence, you can't directly view them inside acad. But you can still embed or link the file and then open the pdf for decompression and viewing. An alternative would be to hyperlink to the pdf. If you need to view inside acad, then you have to extract an image as was suggested earlier.
    C:> ED WORKING....
    LinkedIn
    2005-06
    45
    Thank You. I do need to view it in AutoCAD, so I will use my photo program as suggested. Good thing I work on the company newsletter, or I wouldn't have a photo program!
    Earth
    9,804
    Quote Originally Posted by cadop.89229
    Here are some options:
    http://rkmcswain.blogspot.com/2006/0...df-to-dwg.html
    R.K. McSwain | CAD Panacea |
    13,656
    Hi
    You may wish to review the links found in THIS post.
    Have a good one, Mike
    2005-06
    45
    Quote Originally Posted by rkmcswain
    I copied the graphic to a Word Doc. and inserted that into my drawing. This did the trick! Thanks for your help!
  1. Replies: 1
    Last Post: 2009-12-18, 03:19 PM
  2. Replies: 3
    Last Post: 2007-09-07, 04:36 PM
  3. AutoCAD closes as soon as it is opened
    By amanda_duvall in forum AutoCAD General
    Last Post: 2007-06-19, 07:39 PM
  4. AutoCAD LT 2008 prevent Drawing1 from being opened
    By rodo in forum AutoCAD LT - General
    Last Post: 2007-05-03, 01:16 PM
  5. Can AutoCAD drawing files be opened in Microstation
    By cadmaniac in forum AutoCAD General
    Last Post: 2006-08-25, 04:27 AM
