Results 1 to 1 of 1
Thread: Miscellaneous - Tension Cable / Tic Tac Toe
    Active Member mark.62793's Avatar
    2003-12
    Santa Rosa, California
    50
    Arrow Miscellaneous - Tension Cable / Tic Tac Toe
    Here are some of my Dblocks attached. I attached the two blocks I used to win in a contest a couple months back for Autodesk.
    The most complex one is the Red symbol (Shear wall Dynamic block). This block I created a while ago, and when people ask me to make additions to it. It takes me a while to remember what everything does. Its by far my coolest block.
    There is also a Post Tension cable block that has a HUGE lookup table. This table generates elongation values that used to be done by hand.
    Some others in here are more of our commonly used dynamic blocks.
    I also attached a fun Dynamic block just for kicks I made one night. Kind of hard to play by yourself, so I guess you could Xref it into your drawing, and Refedit to get a multi player game? I dunno??
    If you want to see some more cool dynamic blocks. Check out my BLOG post that traces back to Shaan Hurleys site.
    http://mdouglas.blogs.com/in_the_dyn...head_dyna.html
    P.S. Its a lot less of a hassle to nest your dynamic blocks inside 1 DWG rather than a ton of dynamic blocks them selves. Because you cant do a open when downloading them off a thread. You need to save them, then insert them into a drawing. Just more of a hassle. But this is just my opinion.
    Let me know what you guys think.
  1. Post-Tension Cable Idea for Revit! (wish)
    By tvanryn in forum Revit Structure - General
    Last Post: 2023-03-14, 12:59 PM
  2. RSA 2011 can do RC post tension design ?
    By tngv75955631 in forum Robot Structural Analysis
    Last Post: 2011-05-17, 05:32 AM
  3. Post Tension Details?
    By Chris.Partin in forum Dynamic Blocks - Technical
    Last Post: 2009-11-23, 01:46 PM
  4. Tension Rods
    By bengo in forum Revit Architecture - General
    Last Post: 2009-05-04, 08:20 PM
  5. Canopy Tension Rod
    By cgrover in forum Revit Architecture - Families
    Last Post: 2004-02-20, 07:11 PM
