Results 1 to 10 of 10
Thread: How to set Floating Viewport scale to something like 1”=30’ or 1”=300’
    2006-09
    Birmingham, AL
    15
    Question How to set Floating Viewport scale to something like 1”=30’ or 1”=300’
    I know that I should know the answer to this but I don’t. I use viewports everyday, but always set to them either ¼”=1’-0” or 1/8”=1’-0”. I just use the option in the properties dialog box to set them and lock the viewport.
    Now I need to set them to be in a civil scale, something like 1”=30’ or 1”=300’. I have tried several times today but with no luck. Can someone please help?
    Thanks
    Jimmy
    AUGI Director scott.wilcox's Avatar
    2001-01
    Edmonton, Alberta
    961
    Default Re: How to set Floating Viewport scale to something like 1”=30’ or 1”=300’
    Quote Originally Posted by jparker70
    Thanks
    Jimmy
    Convert your viewport scale to a direct ratio (1"=30' is 1:360 for example) and enter the ratio in the viewport scale box.
    Why draw straws? Just draw one straw and array it.
    Scott Wilcox - Edmonton, Alberta
    2004-08
    Hartford, Michigan
    3,086
    select the viewport in the properties palette, custom scale box, type in 1/30
    Christopher T. Cowgill, P.E.
    WIGHTMAN & ASSOCIATES, INC.
    ENGINEERING <> SURVEYING <> ARCHITECTURE
    AutoDesk Infrastructure Design Suite Premium 2013 x64
    Windows 7 Pro x64
    Houston
    7,543
    Thanks
    Jimmy
    Another method:
    Go into the viewport, run the ._ZOOM command, _Center option, pick a point that will be in the center of the viewport, then enter a scale factor of 1/30XP (for 30 scale). It does not matter if the picked point is exact, since once the scale is set you can pan the viewport contents into place.
    If you are using Map, you can run the ._AECDWGSCALESETUP command, and easily change the "scale list" to reflect typical civil scales such as 1"=30'.
    0,0,0 The Origin
    8,060
    Should that be 1/360XP ?
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    2004-08
    Hartford, Michigan
    3,086
    Quote Originally Posted by jaberwok
    not necessarily, typically for civil, everything is drawn using decimal units, so in a 1 to 1 environment, 1 unit is equal to 1 foot, so the view port needs to be at 1/30XP
    Windows 7 Pro x64
    0,0,0 The Origin
    8,060
    Quote Originally Posted by ccowgill
    Okay, I don't do civils but the OP mentioned 1"=30'.
    John B
    AUGI Addict .chad's Avatar
    2006-04
    is it lunch time yet?
    1,125
    SCALELISTEDIT will bring up a dialogue box to edit VP scale options. if you enter that into the help file it should answer any questions. if it is only one VP, it may not be worth it, but if you use a scale frequently its a great time saver.
    This aggression will not stand. Man.
    2006-09
    Birmingham, AL
    15
    Thanks for the help.
    Jimmy
    Forum Manager, Administrator Ed Jobe's Avatar
    Turlock, CA
    4,791
    A different way. I have a vba routine on the Exchange called SetViewportScale. It allows you to zoom to the approximate view and it chooses the nearest standard scale. You can select from Engineering, Metric or Architectural standard scales.
    C:> ED WORKING....
  1. Replies: 13
    Last Post: 2011-09-10, 11:16 PM
  2. No contour of floating viewport
    By j.aaij in forum AutoCAD 3D (2007 and above)
    Last Post: 2008-03-12, 02:36 PM
  3. What controls new floating viewport zoom scale factor?
    By r424andy in forum AutoCAD General
    Last Post: 2007-02-01, 03:42 PM
  4. Able to Pan only so far within Floating Viewport
    By jeff.garr in forum AutoCAD General
    Last Post: 2006-06-20, 06:14 PM
  5. Scale Dimensions and Text to Floating Viewport scales
    By dkirkpatrick in forum AutoCAD LT - General
    Last Post: 2006-04-12, 10:15 PM
