You can with code.
(defun AddObjectField (AddToEname LinkObj PropName / EntData ExDict FDict PropType PropValue)
(if
(and
(setq EntData (entget AddToEname))
(vl-position (value 0 EntData) '("MTEXT" "ATTRIB" "ATTDEF"))
(setq ExDict
(vlax-vla-object->ename
(vla-GetExtensionDictionary
(vlax-ename->vla-object AddToEname)
(setq PropType
(type
(setq PropValue
(vlax-get LinkObj PropName)
(progn
(dictremove ExDict "ACAD_FIELD")
(setq FDict
(dictadd ExDict "ACAD_FIELD"
(entmakex
(0 . "DICTIONARY")
(100 . "AcDbDictionary")
(280 . 1)
(281 . 1)
(dictadd FDict "TEXT"
(entmakex
(list
'(0 . "FIELD")
'(100 . "AcDbField")
'(1 . "_text")
'(2 . "%<\\_FldIdx 0>%")
'(90 . 1) ;Number of child fields
(cons 360 ;Child field ID
(entmakex
(list
'(0 . "FIELD")
'(1 . "AcObjProp") ; Field type
(cons
(strcat
"\\AcObjProp Object(%<\\_ObjIdx 0>%)."
PropName
'(90 . 0) ; Number of child fields
'(97 . 1) ; Number of object ids
(cons 331 (vlax-vla-object->ename LinkObj)) ; Object id
'(4 . "") ; format string
'(91 . 63) ; evaluation option
'(92 . 0) ; filling option
;'(94 . 59) ; field state flag
;'(95 . 2) ; evaluation status
;'(96 . 0) ; evaluation error code
;'(300 . "") ; evaluation error message
'(6 . "ObjectPropertyId")
'(90 . 64)
(cons 330 (vlax-vla-object->ename LinkObj))
'(6 . "ObjectPropertyName") ; key string for the field data
'(90 . 4) ; data type of field
(cons 1 PropName) ; name of property
'(7 . "ACAD_FIELD_VALUE") ; key string for the evaluated cache
(cons
90 ;data type of field
(cond
((equal PropType 'STR)
4
((equal PropType 'INT)
((equal PropType 'REAL)
((equal PropType 'LIST)
32
(cond ; field value
(cons 1 PropValue)
(cons 91 PropValue)
(cons 140 PropValue)
(cons 11 Propvalue)
'(300 . "") ; format string for '08
'(301 . "") ; format string
'(98 . 0) ; length of format string
'(97 . 0) ; Number of object IDs used in the field code
'(4 . "") ; Format string
'(91 . 63) ; Evaluation option
;kDisable 0 Disable evaluation.
;kOnOpen (0x1 << 0) Evaluate during drawing load.
;kOnSave (0x1 << 1) Evaluate during drawing save.
;kOnPlot (0x1 << 2) Evaluate during drawing plot.
;kOnEtransmit (0x1 << 3) Evaluate during eTransmit.
;kOnRegen (0x1 << 4) Evaluate during regen.
;kOnDemand (0x1 << 5) Evaluate only on demand by the user or the API.
;kAutomatic (kOnOpen | kOnSave | kOnPlot | kOnEtransmit | kOnRegen | kOnDemand) Automatically evaluate fields during all the operations.
'(92 . 0) ;Filling option
;kSkipFilingResult (0x1 << 0) Do not file out the cached evaluation result with the field.
;'(94 . 5) ;Field state flag
;kInitialized (0x1 << 0) Field is not yet intitalized with any field code or data.
;kCompiled (0x1 << 1) Field has been compiled.
;kModified (0x1 << 2) Field has been modified and not yet evaluated.
;kEvaluated (0x1 << 3) Field has been evaluated. Use evaluationStatus() to get the evaluation status.
;kHasCache (0x1 << 4) The field has a cache of the evaluated result.
;'(95 . 1) ;Evaluation status
;kNotYetEvaluated (0x1 << 0) Field is not yet evaluated.
;kSuccess (0x1 << 1) Field is evaluated successfully.
;kEvaluatorNotFound (0x1 << 2) Evaluator was not found.
;kSyntaxError (0x1 << 3) Syntax error in the field expression.
;kInvalidCode (0x1 << 4) Invalid field code or expression.
;kInvalidContext (0x1 << 5) Current context is invalid for evaluating the field.
;kOtherError (0x1 << 6) Evaluation has failed.
;'(96 . 0) ;Evaluation error code
;'(300 . "") ;Evaluation error message
'(93 . 1) ;Number of the data set in the field
'(6 . "ACFD_FIELDTEXT_CHECKSUM") ;Key string for field data
'(90 . 2) ;Data type of field value
'(140 . 33.0) ;Double value
'(7 . "ACFD_FIELD_VALUE") ;Key string from the evaluated cache, hard coded as is shown here
'(90 . 0) ;Data type of field value
'(91 . 0) ;Long value
'(98 . 0) ; format string length
(entupd AddToEname)
Then select the mtext you want, with this code to run ( after you have loaded the above code ).
(AddObjectField
(car (entsel "\n Select mtext entity: "))
(vla-get-Layouts (vla-get-ActiveDocument (vlax-get-Acad-Object)))
"Count"
