Results 1 to 9 of 9
Thread: Electrical Device Shape(Phisical) Modification
    100 Club Binu Mathew's Avatar
    2005-11
    Kuwait
    157
    Default Electrical Device Shape (Physical) Modification
    Does anyone knows how to find a device block name in quick way by clicking on an Electrical Device (Device ID may varies) in ABS 2006 Example(AECBE_UK_FLSA_300x1200_M) if we feel to modify the Device shape physically after established in the layout map.
    to modify the device i normally do insert command and in the block dialogue box, used to find the preview of the block Ex. (AECBE_UK_FLSA_300x1200_M) then insert it double click on that (Refedit command), it takes time to find out the device actual block through insert block dialogue box as we are having lots of devices and its associated blocks
    any other quick method is available ????
    Binu Mathew
    Electrical CAD Designer
    KEO
    Kuwait
    2002-09
    Madison, WI
    4,439
    Default Re: Electrical Device Shape(Phisical) Modification
    If you know the block name you should be able to use the "filter" command.
    Dave Peterson
    Acad 2012 - Revit Structure 2013 - Z220 - Win 7 64 - i7-3770 3.4GHz 32GB Ram
    "The more you know, the less you know, because the more you know you don't know". --M. Lin
    2003-10
    San Francisco CA
    1,190
    Hi Binu,
    I'm not sure if this is what you are trying to accomplish but if you want to change the way a certain device looks permanently you will need to change the block in the content library.
    I use ABS2007 so the path below may be different than ABS2006 but in ABS 2007
    Go to FILE - OPEN and click the Content Folder on the left side of the dialog box. Now go to Aecb Content - US Imperial (or Metric) - Electrical - Devices and choose the device type you want to modify.
    WARNING: I WOULD STRONGLY SUGGEST MAKING A COPY OF ANY OF THESE FILES BEFORE MODIFYING THEM (JUST IN CASE)
    Once in the drawing you want go to:
    FORMAT - Style Manager - Electrical Objects - Devices Styles
    Click on the device you are interested in modifying and go to the views tab. At the top of the dialog box there will be several view names listed (Probably Plan, Model and Reflected) if you click on any of these you will see the name of the block used for this view in the middle of the dialog box.
    Now that you know the name of the block all you need to do is insert it into this drawing, explode it make the modifications you want to make and then recreate the block with the same name.
    I hope that is what you were wanting. If not post back and we'll try to help.
    Scott Telthorst
    Quality Control Manager
    Helix Electric, Inc.
    www.helixelectric.com
    2005-11
    Kuwait
    157
    Quote Originally Posted by david_peterson
    Dear Dave,
    Thanks for the Reply,
    well we can remember the Device ID/Tag but the aassociated block name its very difficult to remember and its a very long name as you may know in Electrical we have plenty of devices and its associated Block.
    i just wanted change my Device shape immediately (as before like list command or any other) its very difficult now in ABS 2006
    i would prefer to keep this in a wish list for the coming version,
    Once again thanks a lots for the Response
    Best rgrds..........Binu Mathew
    2002-09
    Madison, WI
    4,439
    Binu, That's what we're here for. Did Scotts post make sense to you? I'm and ADT guy and I haven't played with ABS yet so I'm not sure how their blocks/components are set up. What ever you do, don't change the orginal. You never know when you're going to want it back.
    If you are going to change a blocks graphics, can't you just pick on it and use the block editor? Just a thought.
    Dave Peterson
    2005-11
    Kuwait
    157
    Quote Originally Posted by stelthorst
    Hi Binu,
    Dear Scott,
    Thanks for the Detailed message its realy appreciated,
    I know the Permenent way what you mentioned we are following that method thru. content library, that is for the main library, in some cases perhaps with in the drawing itself we wanted to edit the shape of the Device.
    to do that as you mentioned to find a device associated block name go to FORMAT - Style Manager - Electrical Objects - Devices Styles
    after finding the block name in this Tab i think we dont need to Explode it insert and Just double click(Refedit command) modify as you wish this is the procedure now what iam doing.
    But Scott iam looking for like the previous AutoCAD if you type List command you will get all the details of the selecting item - this may come in future version well we are now working on ABS 2006, i dont know about 2007.1 we may have it,
    any have lots thanks for your reply Keep it up- by the way do you know how to creat a new Device in your main Library?
    Best Regards
    Binu Mathew
    KEO
    Kuwait
    2002-09
    Madison, WI
    4,439
    Now I know what you are looking for. We have a utility that works like the list command but sees through blocks. ie if you need to know the layer, block name, block scale...... I'm not sure if our IT guy wrote it, or found it. You may try searching the web for "Entity List Utility". I'm sure it's out there, I'm just not sure what you call it.
    Dave Peterson
    2003-10
    San Francisco CA
    1,190
    Quote Originally Posted by BinuM
    Hi Binu,
    I checked in 2007 and listing an electrical device does not tell you the block name(s). At this time the only way I know to find out the block name of an electrical device is thru the FORMAT - Style Manager - Electrical Objects - Devices Styles method. Cumbersome but it works.
    As for your other question. You will need to do the following:
    1. Open to the drawing that best fits the type of device you want to add. (For example if you want to add a receptacle open the Receptacle.dwg in your library.
    2. Create the block(s) you want to use. I typically have a symbol block for the top view and a 3d block for all other views.
    3. Now go to FORMAT - Style Manager - Electrical Objects - Device Styles and click New Style.
    4. Give the style a name and on the view tab add a couple of views (Usually Model and Plan) For the Model view choose the Model display representation, your 3D block, and all view directions but top and bottom. For the plan view choose the Plan display representation, your symbol block, the top and bottom view directions, and if you want it to scale automatically check the "Use Annotation Scale" button.
    5. You can then add connectors, classifications and modify the display properties.
    If you did this all right your new device should be available when you go to the add device dialog.
    Hope this helps,
    Good luck and have fun (That's what w@*k is supposed to be right?)
    Scott Telthorst
    2005-11
    Kuwait
    157
    Good luck and have fun (That what's w@*k is supposed to be right?)[/QUOTE]
    Dear Scott,
    Thanks a lots
    Binu Mathew
  1. Wire does not clean up to Electrical Device
    By jgilroy in forum AMEP General
    Last Post: 2010-09-02, 03:18 PM
  2. Electrical Device with 2 labels?
    By sschwartz in forum Revit MEP - Families
    Last Post: 2009-09-08, 10:06 PM
  3. Electrical device using different colors
    By cfolden in forum Revit MEP - General
    Last Post: 2008-05-05, 04:27 PM
  4. Electrical Schematic Symbol to Device
    By Binu Mathew in forum AMEP General
    Last Post: 2007-02-05, 03:52 AM
