Results 1 to 10 of 17
Thread: How do I make a fence linetype for a site plan
    I could stop if I wanted to Dave Lewis's Avatar
    2004-10
    Orange County
    207
    Default How do I make a fence linetype for a site plan
    I've sketched up my existing site inside autocad and I have chainlink fense's represented by ---x---x---x---x--- When I link the .dwg into revit I loose the linetypes. How can I do a linetype like this in revit.
    Revit Technical Specialist - Autodesk Scott Davis's Avatar
    2003-04
    Chino, CA
    4,743
    Default Re: How do I make a fence linetype for a site plan
    Use a repeating detail component, using a detail componenet you've made with a line and two other crossing lines to represent the X. Since detail lines are visible only in the view they are created in, your line and X combo detail component will need to be sized by you for the scale of the view you plan on drawing them in.
    Scott D Davis
    AEC Technical Specialist
    Autodesk, Inc.
    http://about.me/scottddavis
    The CADSmith Chad Smith's Avatar
    2003-05
    Brisbane, Australia
    1,729
    And make sure you send a wishlist request off to support to have text as part of line patterns.
    2003-11
    New Zealand
    1,116
    I've done similar with line based detail family. You'll need to nest the x detail(if you want scale) and make the spacing an array that calculates the correct number based on the length of the 'line'. Add a scaling factor for different scales.
    HTH,
    Guy
    I could stop if I wanted to Adam Mac's Avatar
    2004-06
    Darwin NT
    319
    .... it certainly helped me - thanks GuyR.
    AMc
    All AUGI, all the time robert.manna's Avatar
    2005-05
    Boston
    777
    If you're interested in actually having a 3D family (plus more options for scheduling an' stuff) you could use a line based generic family (which can then be assigned to any category type). The only catch is that you can't do curves (easily), course you can't do curves easily with repeating details or line based detail components either. Not to mention, how many "curved" fences do you really see, most are faceted.
    To each his own... you could do 2D stuff in the "3D" family and still have more flexibility in scheduling and handeling information.
    HTH,
    -R
    All AUGI, all the time christo4robin's Avatar
    2003-05
    Boulder, Colorado
    681
    Here is a non-scaling version I made.
    Christopher Herr
    Studio H:T
    Republic of Boulder
    2005-05
    Boston
    777
    edit: Because our very good moderators had to make some changes to this thread, I don't know how relevant my post still is (since in my own opinion its being repetitive). I will let it stand the way it is, but I don't want anyone feeling that I'm attempting to be argumentitive, or anything else.
    -R
    The problem here (to my knowledge) is Revit's in-ability to support custom geometric patterns embedded into a line pattern, as opposed to ACAD and Microstation, which both allow you to essentially define any pattern of geometry you like, and call it a "linestyle", where Revit, you're stuck with dash (of any length) or dot, and space (of any length). So the user is looking for a work-around/technique to eliminate this obstacle in line pattern support.
    I would argue that a fence should be defined with a true object and not just a detail component (however that is an entirley different discussion from the one we started with).
    -R
    Last edited by robert.manna; 2007-01-28 at 12:55 PM. Reason: response to edit: Removed spam and reference to it.
    All AUGI, all the time Firmso's Avatar
    2006-03
    Here, Still
    549
    Quote Originally Posted by 4christo4
    Can I ask for a R9.0 Down-Saved version of this File.
    Thanks
    All AUGI, all the time Justin Marchiel's Avatar
    2004-07
    Penticton, B.C., Canada
    954
    REVIT OpEd has a good idea on how to create a fence
    http://revitoped.blogspot.com/
    Take a look at this site.
    Justin
  1. Showing Fence on Site?
    By nsinha73 in forum Revit Architecture - General
    Last Post: 2009-03-11, 08:46 PM
  2. Create a custom Linetype - silt fence
    By gcameron in forum AutoCAD Customization
    Last Post: 2007-06-21, 10:40 PM
  3. Chainlink Fence in Site Plan
    Last Post: 2007-02-06, 11:11 PM
  4. Create a custom Fence linetype
    By Damian_E in forum AutoCAD Customization
    Last Post: 2006-07-12, 08:18 AM
  5. Get fence railing to follow site slope
    By Henry D in forum Revit Architecture - General
    Last Post: 2004-06-25, 01:54 PM
