Results 1 to 8 of 8
Thread: Change / Switch Background colour?
    14
    Lightbulb Change / Switch Background colour?
    I want to make a macro or a custom button to change the background from black to white and white to black. I work in black but need to go to white for screen captures and then back to black to work. A button/macro would save considerable time. Any help woul be appreciated.
    Seppy
    AUGI Addict fixo's Avatar
    2005-05
    Pietari, Venäjä
    1,227
    Default Re: Change / Switch Background colour?
    Quote Originally Posted by joe.szanyi
    Seppy
    Hi Seppy
    Here is an example from ActiveX and VBA Reference Help file
    Sub Example_GraphicsWinModelBackgrndColor()
        ' This example returns the current setting of
        ' GraphicsWinModelBackgrndColor. It then changes the value, and finally
        ' it resets the value back to the original setting.
        Dim preferences As AcadPreferences
        Dim currGraphicsWinModelBackgrndColor As OLE_COLOR
        Set preferences = ThisDrawing.Application.preferences
        ' Retrieve the current GraphicsWinModelBackgrndColor value
        currGraphicsWinModelBackgrndColor = preferences.Display.GraphicsWinModelBackgrndColor
        MsgBox "The current value for GraphicsWinModelBackgrndColor is " _
                & preferences.Display.GraphicsWinModelBackgrndColor, vbInformation, "GraphicsWinModelBackgrndColor Example"
        ' Change the value for GraphicsWinModelBackgrndColor
        preferences.Display.GraphicsWinModelBackgrndColor = 16
        MsgBox "The new value for GraphicsWinModelBackgrndColor is " _
        ' Reset GraphicsWinModelBackgrndColor to its original value
        preferences.Display.GraphicsWinModelBackgrndColor = currGraphicsWinModelBackgrndColor
        MsgBox "The GraphicsWinModelBackgrndColor value is reset to " _
    End Sub
    You need take a look at GraphicsWinLayoutBackgrndColor property
    in this Help file also
    Hth
    ~'J'~
    "The whole problem with the world is that fools and fanatics are always
    so certain of themselves, and wiser people so full of doubts."
    Bertrand Russell
    14
    Thanks Fixo,
    How do I find the help file that you reference? I pasted this example into the VBA editor and nothing happened when I ran it (the message boxes came up but that was about it). I played with different colours and numbers but nothing happened. If I can find the help file where you got this example from I believe I could work my way through it.
    Seppy
    2005-05
    Pietari, Venäjä
    1,227
    Thanks Fixo,
    Seppy
    Open module with this code,
    say select GraphicsWinModelBackgrndColor word
    then press F1 and you will be on this Help file page
    I've tested this example in A2005 only, works fine for me
    This one changed screen color from white to black
    and otherwise
    ~'J'~
    Bertrand Russell
    14
    That's all that I needed! Thanks for the quick answers! People like you make this forum awsome!
    Seppy
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    6,854
    The following AutoLISP code snippets will do this. You could put them on two separate buttons on a toolbar.
    ;White Background
    (COMMAND "VBASTMT" "ThisDrawing.Application.Preferences.Display.GraphicsWinModelBackgrndColor = 16777215")
    ;Black Background
    (COMMAND "VBASTMT" "ThisDrawing.Application.Preferences.Display.GraphicsWinModelBackgrndColor = 0")
    2005-05
    Pietari, Venäjä
    1,227
    Seppy
    C'mon
    No flowers please
    I am no so smart as you means
    Happy computing
    Cheers
    ~'J'~
    Bertrand Russell
    2006-05
    260
    Seppy
    Hi Seppy,
    If you capture in WMF format, you can have a look at these two system variables also.
    WMFBKGND
    WMFFOREGND
    Regards,
    Abdul Huck
  1. Phase Override Background Cut Colour
    By d.stairmand in forum Revit Architecture - General
    Last Post: 2010-04-12, 02:46 AM
  2. Background colour
    By wernerfontein in forum AutoCAD General
    Last Post: 2009-10-06, 03:41 PM
  3. Change all Objects of one colour to another colour
    By tburke in forum AutoCAD General
    Last Post: 2006-10-17, 02:55 PM
  4. Text background masking, make default and change its colour
    By nick.107433 in forum AutoCAD General
    Last Post: 2006-03-02, 11:11 AM
  5. background colour in elevation
    By Max Lloyd in forum Revit Architecture - General
    Last Post: 2005-07-11, 03:02 PM
