Thread: Greetings and a quick question....
    2004-01
    2
    Default Greetings and a quick question....
    Hello All,
    I will be completing my RS5 training this week and thrown into my first project next week kicking and screaming.......just kidding.
    I will be monitoring tis board and will try to help whenever I can.
    we typically show steel elevations at a column line in ''single line'' mode depicting top of steel and centerline of vertical (wind) bracing. I successfully changed the settings to depict top of steel for my beams but when I did this it also changed my bracing to show top of steel. When I select the brace, the work points are in the correct location. Any ideas on how to show both the beams and bracing correctly?
    Thanks a million in advance.
    Tony Acker
    Structural Engineer
    Senior Structural Designer
    STV, Incorporated
    Pittsburgh, PA
    2004-12
    New Jersey
    179
    Default Re: Greetings and a quick question....
    Training in RS5? Is that a pre-release version?
    Thomas E. Maleski, EIT
    Revit Trainer and Consultant
    Autodesk Implementation Certified Expert
    Autodesk Revit Architecture 2012 Certified Professional
    AutoCAD, AutoCAD Architectural, AutoCAD MEP
    Revit Architecture, Revit Structure, Revit MEP
    2004-01
    2
    Sorry.....meant to be RS4.
    2006-01
    Milwaukee, Wisconsin
    383
    Welcome to the forums Tony,
    If I may ask, how did you achieve the top of steel for your beams? The reason I ask is that there is a setting (under instance parameters-Structural) called Stick View On Top. Just select the member(s) you want to have with the single line representing the top of steel and in the properties check that box. This should get you where you want to be (unless I'm not understanding you).
    Good Luck with the class!
    __________________
    Rick McElvain
    Arnold and O'Sheridan
  1. Quick question
    By preddy08 in forum DWF Viewer - General
    Last Post: 2008-11-11, 11:39 PM
  2. A quick question
    By gautamrs in forum Revit Architecture - General
    Last Post: 2008-05-12, 07:25 PM
  3. A qq (quick question)
    By dpasa in forum Revit Architecture - General
    Last Post: 2007-02-27, 03:17 PM
