Results 1 to 6 of 6
Thread: Splitting a large rvt
    2007-01
    39
    Default Splitting a large rvt
    we currently have a large town centre masterplanning being undertaken in revit. we now have massing models in revit which we would like to develop which will eventuate into construction docs if all goes well.
    question:
    how do we seperate the massing models of the individual buildings into individual files to develop from?
    100 Club dtownsend's Avatar
    2006-06
    Atlanta, GA
    163
    Default Re: Splitting a large rvt
    What I would do is create at least one new file for each building, the site, and a file for the total project.
    [This is assuming that your massings are just massing and you haven't added floors, walls, etc.]
    Then in your existing file you can copy one of the massed buildings and paste it into the new file for that building. You will also want to try to paste to the correct location, but it is not a big deal since you can reassign shared coordinates at anytime.
    If you have added floors, walls, etc. - I would copy each floor one at a time.
    Tip: If you are going to need to use the Project Internal Coordinates for lining up the buildings (ie. your using NavisWorks which uses the Internal Coordinates for some reason) you can create an AutoCAD DWG of the site and set your coordinates up in AutoCAD then import the AutoCAD file into all your Revit files - just make sure you choose the "Origin to Origin" option when linking in the AutoCAD files. You will then paste the Massing in its correct location based on the CAD File. I would still set-up the shared coordinates too, but this is just to make exporting to NavisWorks easier.
    Once you get all your buildings pasted in and files saved out you can open the "main" file and link all the files in.
    I would also suggest looking into using Work sets - if you haven't done so already.
    All AUGI, all the time cphubb's Avatar
    2003-11
    Seattle
    691
    You can also do a saveas... for each building and the site. You can then erase the buildings you do not need and relink the buildings back to the main site plan. I agree you should have a seperate file for each building, and the site.
    2006-06
    Atlanta, GA
    163
    Quote Originally Posted by cphubb
    Yeah that is a good way to do it!
    Although you miss out on all the copy and paste fun!
    2007-01
    39
    thanks guys!
    i was hoping there would be a "save selected as" button somewhere that i missed. will give both methods a go.
    also i noticed that when i cut a section through a topography, the section cut (hatching of the "earth") ends just below the 0 level datum line. is there a way to display the sectional earth hatch further below the 0 datum level? (eg -3000 RL ?)
    100 Club D_Driver's Avatar
    2003-11
    Ashland Oregon
    194
    Look in Settings>Site Settings
    in this dialog there is a setting to set
    Elevation of poche base
    DdDD
  1. 2015: Splitting a large revit model
    By f.richarz503713 in forum Revit Architecture - General
    Last Post: 2015-04-14, 02:33 PM
  2. Splitting Splines
    By craighowie in forum Revit Architecture - General
    Last Post: 2010-03-05, 11:57 PM
  3. Splitting schedule
    By nebojsa.jeremic in forum Revit Architecture - General
    Last Post: 2005-06-10, 05:50 PM
