Results 1 to 10 of 15
Thread: ADT 2007 - How can I disable jitter so I can plot with ctb plot styles?
    All AUGI, all the time thomas.stright's Avatar
    2004-07
    Central Maryland
    531
    Default ADT 2007 - How can I disable jitter so I can plot with ctb plot styles?
    How can I disable jitter so I can plot with ctb plot style??
    Coordination Department Manager
    Heffron Company
    "Only the Skilled Survive" and having a CWP helps
    I could stop if I wanted to sschwartz's Avatar
    2005-04
    Oakland County, Michigan
    424
    Default Re: ADT 2007 - How can I disable jitter so I can plot with ctb plot styles?
    Quote Originally Posted by thomas.stright
    Uh.... what's a jitter?
    2004-07
    Central Maryland
    531
    Quote Originally Posted by sschwartz
    Makes lines appear sketched. Part of Visual Styles.
    Heffron Company
    2005-04
    424
    Um... what version of autocad are you running?
    Look at the bottom of this screen, you will see some other posts with the word Jitter in them...
    2005-07
    2,354
    I think its a Revit thing.
    2004-07
    Central Maryland
    531
    Quote Originally Posted by Steve.Sanderson(UK)
    ADT 2007 SP1
    Heffron Company
    2005-07
    2,354
    ADT 2007 SP1
    Oh, shows what I know, I assumed Revit because of the similar threads at the bottom (note to self, don't assume).
    Edit:
    Okay now I see what you mean http://www.ellenfinkelstein.com/Auto...ual_style.html
    Can you create a custom visual style to remove the edge jitter.
    2004-07
    Central Maryland
    531
    From what I'm reading (help file) all Visual Styles have it. I've created one with a jitter of 0(zero) and the CTB still is not applied upon plotting. Just weird.
    Heffron Company
    2005-07
    2,354
    I only have 2007 at work so will take a look at it tomorrow, one thing though, where it says 'facet edges' can that be changed to smooth?
    2005-07
    2,354
    I can remove the jitter and overhang by adjusting the settings on the dashboard, but for plotting I think the visual style overrides the ctb settings, also in the page setup the shaded viewport mode overrides the visual style (unless you pick as displayed).
    Can you edit/create a visual style to get the results you want?
  1. Plot Styles and Plot Configs
    By mvsawyer in forum AutoCAD General
    Last Post: 2010-05-18, 06:00 AM
  2. Replies: 4
    Last Post: 2007-03-12, 11:48 AM
  3. Replies: 5
    Last Post: 2007-02-12, 11:53 PM
  4. Replies: 2
    Last Post: 2006-07-27, 10:30 PM
