Thread: AutoCAD 2007 plot dialog closes on its own when plot selected from right-click menu
    2004-08
    Hartford, Michigan
    3,086
    Default AutoCAD 2007 plot dialog closes on its own when plot selected from right-click menu
    has any one experienced a problem when previewing a plot and using the right click menu to plot with the command just exiting out. the user experiencing this is the only one in the office because no one uses that method of plotting, we are on 07
    Christopher T. Cowgill, P.E.
    WIGHTMAN & ASSOCIATES, INC.
    ENGINEERING <> SURVEYING <> ARCHITECTURE
    AutoDesk Infrastructure Design Suite Premium 2013 x64
    Windows 7 Pro x64
    Certifiable AUGI Addict Wanderer's Avatar
    2001-12
    St. Louis
    4,260
    Question Re: AutoCAD 2007 plot dialog closes on its own when plot selected from right-click menu
    Quote Originally Posted by ccowgill
    I haven't had a problem myself so far...
    just to clarify, you're saying the user set up their print, goes to plot, previews, then goes to right-click (either to finish the plot, or to return to the plot dialog?)
    any system information? (assuming you are using the same OS with the same SP's and the same plotter drivers, etc?)
    Melanie Perry @MistresDorkness
    Facilities CAD Management (FM - MEP/FP)
    Technical Editor
    Revit MEP 2013 Suite
    not all who wander are lost
    AUGI Addict .T.'s Avatar
    Lost
    1,473
    Default Re: AutoCAD 2007 plot dialog closes on its own when plot selected from right-click menu
    When you right click while in a plot preview and click Plot instead of Exit, it's just skips going back to the settings dialog and sends it to the plotter with the settings that created the plot preview. I use this method all of the time. Did nothing come out of the plotter?
    Tim Creary
    S&D
    DILLIGAF
    Administrator Steve_Bennett's Avatar
    2004-05
    Somewhere near there
    4,627
    One thing I've tried in the past when it's just one user in the office is to revert to the ootb profile and see if the problem persists. Then you know if it is user related or system related.
    Steve Bennett / CAD Manager
    HMC Architects / Adventures in BIM
    2004-08
    Hartford, Michigan
    3,086
    from what I understood, it exited when he right clicked, it didn't give him time or an option to click anything else in the shortcut menu. No one else in our office has ever complained about such a problem, he is the only one, the way I understood it, he reset the profile but that didn't help. my problem is, I dont use plot preview any more, I run a series of programs that as long as the titleblock is positioned properly, the program plots using predefined page setups and requires no user input.
    Windows 7 Pro x64
  1. Replies: 5
    Last Post: 2007-02-12, 11:53 PM
  2. Unable to edit plot style table though plot dialog box
    By mike.smith696451 in forum Land Desktop - General
    Last Post: 2006-12-20, 02:11 PM
  3. AutoCAD 2006 Closes / Exists during Plot command
    By BushDog1 in forum AutoCAD General
    Last Post: 2006-07-24, 03:53 AM
  4. ADT 2007 - Right click menu missing when nothing is selected
    By sgrinavi in forum AutoCAD CUI Menus
    Last Post: 2006-07-21, 05:01 PM
  5. Plot on Right click Menu
    By jgratton in forum AutoCAD General
    Last Post: 2005-07-25, 06:12 PM
