Results 1 to 6 of 6
Thread: View Range for Roof Plan
    All AUGI, all the time ford347's Avatar
    2005-01
    Oroville, CA
    874
    Default View Range for Roof Plan
    I have a 2-story home project in which the upper roof carries down to the lower roof at the back of the house. I want to show a '1st floor roof plan', but where the view range is set to the second floor line so it shows the lower roof, the eaves from the upper roof are showing. I've tried using the filter tool to shut one of the roofs off, but I can't seem to get it to work....obviously I'm missing something. I can't find a comfortable point with a plan region to accomplish what I would like to see here.
    Anybody have any suggestions?
    Thanks.
    Josh
    "Rock-n-Roll Architect" SCShell's Avatar
    2004-01
    Tucson, AZ
    1,272
    Default Re: View Range for Roof Plan
    Hey there,
    I ran into this same type of problem once, on a little office building that had a similar roof condition.
    I just added a new "Phase" after New Construction. Then used the phase overrides to control how the different views looked.
    The other option may be by using Design Options. Just make the upper roof an option.
    Hope this helps maybe
    Good luck
    Steve
    100 Club ghale's Avatar
    2006-07
    Rochester, NY
    142
    Using scope boxes may also be an option.
    AUGI Addict Joef's Avatar
    2003-12
    Victoria, BC
    1,273
    Filter should work. What I do is place a word in the comment field and filter roofs for comment = that word. Quick and dirty but it works. I filter out all the basement walls and doors in a foundation plan that way. Saves lots of hassle.
    2005-01
    Oroville, CA
    874
    Thanks guys!
    I'll probably opt to play around with the phasing idea. I have 2 permenant design options for this house anyway as it is for use in a tract project, so I'd hate to confuse myself with another option. The phase seems like a reasonable resolution. Thanks again.
    Josh
    2005-01
    Oroville, CA
    874
    I created a new phasing category called visibility phase. I assigned the upper roof to this phase. I set up a new filter so that it would not display this phase when needed and also adjusted the other filters to show this phase when needed. In any case, I cannot get this roof to show up when this phase is assigned to it??? Any ideas. What am I doing wrong.
    Josh
    edit: I also tried moving this phase to both the past and future sides of the new construction phase to see if this changed anything and it did not.
  1. Plan Region View Range for RCP
    Last Post: 2013-11-15, 03:29 AM
  2. view range in plan regions
    By jordank in forum Revit - Platform
    Last Post: 2007-11-14, 08:07 PM
  3. View Range for Ceiling plan
    By bgauthier in forum Revit Architecture - General
    Last Post: 2007-04-23, 05:01 PM
  4. Plan Region - View Range Tutorial
    By cadclips81126 in forum Revit - Tutorials
    Last Post: 2007-04-11, 11:12 PM
  5. View Range with Structural Plan
    By ford347 in forum Revit Architecture - General
    Last Post: 2007-03-01, 02:38 PM
