Recently we have move from ACAD04 to ACAD06, and of course we have some custom menus that needed to be moved from the old to the new. All is well except that one menu seems to have issues. When this option from the menu is selected, the window does come up as it should but the data that should display in it does not. There are also three question marks at the top of this window. I have posed the code below, could some one point me in the right direction as to how to get these menus working. (I have pointed 06 to the necessary folders in the “Support File Search Path”). Thanks for your help in advance.
This is the portion that does not work, in 06 but does work in 04
[S.H.C.S.]^C^C$I=image.shcs $I=*
[B.H.C.S.]^C^C$I=image.bhcs $I=*
[F.H.C.S.]^C^C$I=image.fhcs $i=*
[S.H.S.S.]^C^C$I=image.shss $i=*
This is the file as is.
// AutoCAD menu file - C:\ACADTOOLBARS2004\MYPULLDOWN.mnu
***MENUGROUP=MYPULLDOWN
***POP1
[Punch/Screw]
[SET SCREWS]^C^C $i=image.sets $i=*
[COMPONENTS]^C^C $i=image.cpnts $i=*
[ROUTINES]^C^C $i=image.routines $i=*
[DETAILING]^C^C $i=image.details $i=*
[->Dayton ]
[DDVERSA]^C^CDDVERSA
[DDBALL]^C^CDDBALL
[<-DDSPRING]^C^CDDSPRING
[->Drill or Tapped Holes]
[Top View]^C^C(load "c:/lisp/tap") tap
[<-Side View]^C^C(load "c:/lisp/drill") drill
[->Dowels]
[Top View]^C^C(LOAD "C:/LISP/DOWEL") DOWEL
[<-Side View]^C^C(load "c:/lisp/dowel2") dowel2
[Springs Top View]^C^C(LOAD "C:/LISP/SPRING") SPRING
[Slot Top View Cen to Cen]^C^C(LOAD "C:/LISP/SLOTPASCH") SLOTPASCH
[Slot Top View Len X Width]^C^C(LOAD "C:/LISP/SLOT") SLOT
[Stock Pusher]^C^C-INSERT *C:/DRAWINGS/MASTERS/STKPUSH \
[Finger Stop]^C^C-INSERT *C:/DRAWINGS/MASTERS/FINGSTOP \
[Die Strap]^C^C-INSERT *C:/DRAWINGS/MASTERS/DIESTRAP \
[Section Line]^C^C(LOAD "C:/LISP/SECTION") SLINE \
[Arc Dimension]^C^C(LOAD "C:/LISP/ARCDATA") ARCDATA \
