Results 1 to 8 of 8
Thread: VLIDE and AutoCAD not Functioning Together
    2004-08
    Hartford, Michigan
    3,086
    Default VLIDE and AutoCAD not Functioning Together
    I think I might have changed a setting somewhere, but I don't know where. My AutoCAD and VLIDE used to work fine together. Now to switch back to autocad with vlide open I have to click on the Activate AutoCAD button and to bring VLIDE back up, I have to type in VLIDE. I used to be able to just click on the taskbar minimized program to switch. It just doesnt work anymore.
    Christopher T. Cowgill, P.E.
    WIGHTMAN & ASSOCIATES, INC.
    ENGINEERING <> SURVEYING <> ARCHITECTURE
    AutoDesk Infrastructure Design Suite Premium 2013 x64
    Windows 7 Pro x64
    Houston
    7,519
    Default Re: VLIDE and AutoCAD not Functioning Together
    I've always noticed strange behavior between VLIDE and AutoCAD. About 1/2 of the time, switching back to the VLIDE requires typing VLIDE at the command line - ever though it's plainly open on monitor #2.
    AUGI Addict kennet.sjoberg's Avatar
    2002-05
    1,706
    Jepp.. sometimes [Alt] [Tab] to AutoCAD and then type Vlide on the Command line
    has rescued me from killing the AutoCAD process in the taskbar. . .
    : ) Happy Computing !
    kennet
    Houston
    7,519
    Red face Re: VLIDE and AutoCAD not Functioning Together
    Quote Originally Posted by kennet.sjoberg
    sometimes [Alt] [Tab] to AutoCAD and then type Vlide on the Command line has rescued me from killing the AutoCAD process in the taskbar
    Good point! I forgot to mention this.
    2004-08
    Hartford, Michigan
    3,086
    I dont quite follow, if VLIDE is open, I can not do anything in AutoCAD until Vlide is closed, or I use the Activate AutoCAD button, then if AutoCAD is active, and I switch to VLIDE, I get a funny looking mouse cursor that has the top left quadrant of the standard autocad cursor with some () in it. and I cant exit vlide until I go back to AutoCAD, type in VLIDE, it switches and then I can close VLIDE, but until I do, I cant do anything in AutoCAD
    I cant post a copy of the cursor, when I do a print screen, it doesnt show up
    Windows 7 Pro x64
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    6,836
    Do you have the "Autoactivate AutoCAD" checked? This can be found under Tools -> Environment Options -> General Options.
    Mine is currently checked.
    2004-08
    Hartford, Michigan
    3,086
    That was exactly what it was, somehow I must have accidently unchecked it.
    Windows 7 Pro x64
    2002-01
    jUSt Here (a lot)
    6,836
    Quote Originally Posted by ccowgill
    I was guessing that was the problem. Glad to know that was it.
  1. VLIDE will not stay open? Any Help Appreeciated.
    By ReachAndre in forum AutoLISP
    Last Post: 2009-07-08, 05:13 AM
  2. Vlide Editor
    By CadDog in forum AutoLISP
    Last Post: 2009-04-01, 06:06 PM
  3. VLIDE hanging
    By cadtag in forum AutoLISP
    Last Post: 2008-08-30, 07:15 AM
  4. AutoCAD 2008 do the icons in VLIDE look odd
    By Steve Johnson in forum AutoCAD General
    Last Post: 2007-05-09, 03:21 AM
  5. Replies: 2
    Last Post: 2006-10-06, 02:32 AM
