Thread: Trapezoid styles
    I could stop if I wanted to Matt Brennan's Avatar
    2005-02
    Vancouver, B.C. Canada
    281
    Default Trapezoid styles
    Hi All,
    I have searched all through the content browser and the web for a trapezoid window that appears in the attached dwf file. I even tried rotating it with in the wall after the standard trapezoid window was placed.
    Does anyone have a style like this? If you could please post it would be greatly appreciated. Otherwise it looks like I will have to create this one from scratch or use a window assembly (curtain wall) to do the job. But like I said, if anyone has, it would be greatly appreciated.
    A huge thanks in advance,
    2002-09
    Madison, WI
    5,687
    Default Re: Trapezoid styles
    This will have to be a 100% custom style. Place a window in a wall, a Picture window should work great. Right click on the window and select Copy and asign new style, re-name it. Next, pick the window and select "Edit profile in Place". Now you can remove a vertex, or shorten it, what ever you want. Then pick save. That's option one. You could also create a profile from a pline and apply that to a window style. Just some thoughts. I hope this helps.
    2005-02
    281
    Nice!!! I totally forgot about that function in ADT. It is such an easy tool to use.
    Much appreciated!!!! Thank you again.
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,730
    Why not just draw a closed polyline, convert it to a profile and edit the window style to use the profile for the shape? That's what I did in the attached graphic.
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
    2002-09
    Madison, WI
    5,687
    Quote Originally Posted by Steve_Bennett
    Thanks was my first thought, but I figured the edit in place was just a slightly easier method if you only had one window.
    On another note, this same theory works for doors as well. You can create a profile for (I believe) both the door slab and any inset glass that you could want. When I took my ADT class we made a Door style with a Mickey Mouse type profile for the door slab and a Goofy looking piece of glass. Our instructor was realy into Disney.
  1. 2014: Trapezoid walls
    By ryanmcphee2367669 in forum Revit Architecture - General
    Last Post: 2013-03-28, 06:57 AM
  2. wall with trapezoid plan
    By alkyon in forum Revit Architecture - General
    Last Post: 2012-03-13, 07:32 AM
  3. Transition 'trapezoid' in Graphical 1-Line view of Pipe
    By dtiemeyer in forum AMEP General
    Last Post: 2008-12-18, 04:14 PM
  4. Trapezoid window
    By bob.86982 in forum Revit Architecture - General
    Last Post: 2008-07-07, 06:08 AM
  5. Lisp Fishing Trapezoid
    By robert.1.hall72202 in forum AutoLISP
    Last Post: 2005-06-21, 12:35 PM
