Results 1 to 10 of 12
Thread: Setting Plot Style Table in Lisp
    2004-12
    California
    283
    Default Setting Plot Style Table in Lisp
    Afternoon -
    I need to build into my lisp a way to set the appropriate plot style table and make it active.
    I've searched through the forums here and no one really gave an answer, so please do not post links to other posts!
    I've tried the following list with nothing working.....
    (vla-RefreshPlotDeviceInfo objLayout)
    (vla-Put-StyleSheet objLayout "MyStyle.stb")
    ThisDrawing.ActiveLayout.StyleSheet = "MyStyle.stb"
    (vl-load-com)
    (vla-put-PrinterStyleSheetPath (vla-get-Files (vla-get-Preferences (vlax-get-acad-object))) "MyStyle.stb")
    I've attached a pic of the tool itself from the options dialog box but I need a way of doing this from the command line for the lisp routine.
    Any suggestions?
    Houston
    7,520
    Default Re: Setting Plot Style Table in Lisp
    So are you trying to set "default" STB file (for use with R14 and previous drawings - as your photo shows), or are you trying to set the current STB file for a particular layout?
    IF the former...
     (setq o (vla-get-Output (vla-get-Preferences (vlax-get-acad-object))))
     (vla-put-PlotPolicy o 0)
     (vla-put-DefaultPlotStyleTable o "monochrome.stb")
    IF the latter.....
    See this post for an example of setting the "stylesheet" for multiple layouts in multiple drawings.
    If you just want to operate on the current layout, then here is a lisp example:
      (vla-put-StyleSheet
        (vla-get-ActiveLayout
      	(vla-get-ActiveDocument (vlax-get-acad-object))
        "monochrome.stb"
    2004-12
    California
    283
    I am getting the following error on both routines.....
    "Automation Error. Invalid input"
    What's that?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    6,836
    Quote Originally Posted by fletch97
    What's that?
    Have you run the following function?
    (vl-load-com)
    2004-12
    California
    283
    Nope but I just added it in and I got the same error for the second routine and basically the same error for the first routine except it says "invalid argument" instead of "input".
    Any Ideas?
    AUGI Addict .T.'s Avatar
    Lost
    1,473
    Any Ideas?
    If you did a staight copy and paste of RK's code, does monochrome.stb exist?
    Or if you changed it, can Autocad find the one you are trying to set?
    Just a guess, though.
    HTH
    Tim Creary
    S&D
    DILLIGAF
    2004-12
    California
    283
    I changed the name to ours, which is there.....not sure why RK's routine won't work?
    Command: (setq o (vla-get-Output (vla-get-Preferences (vlax-get-acad-object))))
    #<VLA-OBJECT IAcadPreferencesOutput2 0b1d7b18>
    Command: (vla-put-PlotPolicy o 0)
    nil
    Command: (vla-put-DefaultPlotStyleTable o "hmc-std.stb")
    *Cancel*
    Command:
    Command:
    Command: Automation Error. Invalid Argument
    Lost
    1,473
    nil
    *Cancel*
    Command:
    Command:
    You are using R14?
    If so, I don't have it to test it; maybe someone else will chime in.
    I did test the second one in 2006, and it returned a similar error message when the file wasn't found, but worked correctly when it was. This would lead me to believe that maybe there is something amiss with the file name specified.
    Tim Creary
    S&D
    DILLIGAF
    2004-12
    California
    283
    I am running ADT 2006
    The file is there because I can see it as an option in the dialog box for the options menu as well as in the layer manager. So how can I get this to set it from the command line?
    Take a look at my first attachment on my first post.....you can see my stb file there.
    Lost
    1,473
    OK.
    I think you need to use RK's second example instead of the first. I couldn't make the first one work in 2006, either, and It may be because of a change between versions. Maybe RK will verify later.
    Have you tried the second example? Here is what I did:
    I wrapped the code in a defun called test and loaded it.
    (defun c:test ()
     (vla-put-StyleSheet
        "Black.ctb"  ;;<--we still use CTB, yours would be hmc-std.stb
    Then I went to a layout and changed the plot style to something else, then executed test at the command line. Then I went back into the layout manager to verify that it changed it to Black.ctb.
    It works here. (2006) Maybe someone that uses STBs will verify it for STBs.
    Tim Creary
    S&D
    DILLIGAF
  1. setting the plot style
    By rstiles in forum AutoLISP
    Last Post: 2012-02-10, 06:54 PM
  2. Unable to edit plot style table though plot dialog box
    By mike.smith696451 in forum Land Desktop - General
    Last Post: 2006-12-20, 02:11 PM
  3. Setting Hatch style with visual lisp?
    By jmcshane in forum AutoLISP
    Last Post: 2006-11-24, 02:58 PM
  4. Replies: 1
    Last Post: 2006-10-13, 04:58 PM
  5. Plot style Table
    By rputhenv in forum AutoCAD Plotting
    Last Post: 2005-03-05, 07:30 AM
