I don't have a way to put them back, but I can offer a easy way to identify the lil buggers.
;;; FUDGE.LSP Version 1.0
;;; Copyright (C) 1996 by Jay Garnett
;;; Permission to use, copy, modify, and distribute this software
;;; for any purpose and without fee is hereby granted, provided
;;; that the above copyright notice appears in all copies and
;;; that both that copyright notice and the limited warranty
;;; below appear in all supporting documentation.
;;; JAY GARNETT PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS.
;;; JAY GARNETT SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
;;; MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. JAY GARNETT
;;; DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
;;; UNINTERRUPTED OR ERROR FREE.
;;; DESCRIPTION
;;; Finds any "fudged" dimensions and automatically changes them to a layer called FUDGED-DIMS.
;;; By Jay Garnett
;;; Bolingbrook, IL
;;; E-Mail jgarnett@enteract.com
(defun c:FUDGE(/ DIM-TXT E1 FUDGED IDX SS)
(setq SS(ssget "x" '((0 . "DIMENSION")))
IDX 0
(while (< IDX (sslength SS))
(setq E1(entget( ssname ss IDX )))
(setq DIM-TXT(cdr(assoc 1 E1)))
(if (and(not(wcmatch DIM-TXT "*<>*"))(/= DIM-TXT ""))
(if (not FUDGED)
(setq FUDGED(ssadd (ssname SS IDX)))
(setq FUDGED(ssadd (ssname SS IDX) FUDGED))
);end if
(setq IDX (1+ IDX))
);end while
(if FUDGED
(progn
(if (not(tblsearch "layer" "FUDGED-DIMS"))
(command ".layer" "M" "fudged-dims" "c" "magenta" "" "")
);end if
(command ".change" FUDGED "" "p" "la" "fudged-dims" "")
(alert (strcat (itoa(sslength FUDGED)) " fudged dimensions changed \nto Layer FUDGED-DIMS"))
);end progn
(alert "No fudged dimensions found in this drawing")
);endif
);end defun
