Results 1 to 6 of 6
Thread: Single mouse click to edit single line text
    2005-01
    52
    Default Single mouse click to edit single line text
    I've noticed when selecting single line text boxes, instead of needing to double click to select, after a while all I have to do is click it once to open, which is great! Is there a way to set this feature on all the time?
    0,0,0 The Origin
    8,060
    Default Re: Single mouse click to edit single line text
    (In later versions) if you press Enter to stop editing an item you need to double-click to select the next item. If you single-click outside the editor you only need a single-click to select the next.
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    2005-01
    52
    Tried it but that doesn't work. Now I'm trying every which way but still need to double click. One click on the mouse was working last week... I have about 500 Items to click; at least I'll get a good work out
    2005-01
    52
    Figured it out: if you press the Enter key twice quickly, the next time you open the text box it does it in one click. To turn off, hit Enter key twice again.
    0,0,0 The Origin
    8,060
    Quote Originally Posted by cjshaw
    That's neat. What version are you using?
    John B
    2005-01
    52
    AutoCAD LT 2004
  1. Associative Single Line Text
    By Light Guy in forum AutoCAD General
    Last Post: 2008-12-15, 11:46 AM
  2. line cannot be selected by single left click
    By jacek.brzezowski in forum Revit - Platform
    Last Post: 2008-09-25, 12:13 PM
  3. How do you combine single line text?
    By cadkiller in forum Revit Architecture - General
    Last Post: 2005-02-03, 03:06 AM
