Page 1 of 5 12345 LastLast
Results 1 to 10 of 43
Thread: Geodesic Dome
    Active Member swissclive54638's Avatar
    2003-10
    London
    50
    Default Geodesic Dome
    Hi
    Does anybody out there know how I would model a geodesic dome (as a roof) in Revit? The structure would be something like the attached image.
    Many thanks.
    2006-03
    London, UK
    810
    Default Re: Geodesic Dome
    I wouldn't even attempt it.
    I would use 3d studio or similar to create the mesh, and then import that back in Revit. Unless you do all the facet calculations by hand and do individual cuts for each face, Revit just can't do this sort of modelling.
    2003-10
    92
    Tom is right...3dstudio max or viz is probably your best option. Export that geometry as a 3d dwg from max, create a new mass in Revit & then import the 3d dwg into the mass. Then use curtain wall be face to generate the form. Its not going to be exactly how you want it, but its probably a good start place.
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    I would think it fairly easy to create a dome, then a face based family in the shape of your structure, then piece it all together.
    Scott D. Brown, AIA
    BECK
    2005-07
    Somewhere in the BIM world
    3,792
    The dome wont be an issue, it's the panel that will be. So i also think that your best bet would be to do it in another program (faster).
    Digital Delivery Director Brian Myers's Avatar
    2003-02
    Stillwater, Oklahoma
    1,819
    3DS would be the best option, but it wouldn't be impossible to do in Revit, just time consuming and likely a bit frustrating. Another option (if a fudge factor or just looks is an option) would be to create a massing object (Solid/Void Revolve, etc) and then apply a geodesic material/surface pattern to it.
    2002-02
    St. Louis, MO
    4,695
    Quote Originally Posted by Dilbert
    ... and then apply a geodesic material/surface pattern to it.
    Unfortunately, Revit materials don't map to compound curve surfaces...
    I could stop if I wanted to Phil Read's Avatar
    2003-05
    Charlotte, NC
    398
    I believe this could be done in Revit as a series of blends if you use maintain three or four sided faces. More than this will be dang tricky and probably worth creating elsewhere and importing.
    -Phil
    PS. Does it bug anyone when the word "Revit" is not recognized when you Spell Check before submitting?
    2006-01
    4,516
    LOL, for what its worth...
    I thought i had a way to compile one in a family pretty quickly... I did a test with it, and the whole thing (so far) took like 5 minutes.... Until i hit finish sketch, LOL... My computer has been grinding away with one processor maxed out since then, bwahahahaa....
    Doable in Revit, but probably way easier elsewhere. Especially if Max will automatically compile the geometry measurements...
    EDIT: Phil, thats what i had done. The blends work fine, as ling as where the "points" have to be the sketch technically has a very small line there. That way it doesnt default to "twisting" to connect the top and bottom. You need a line with two vertices to connect to the sketch below.
    I had the same happen trying to create a blend like the Freedom tower. Square in a square sketch = rotated square. A square with 4 tiny chamfered corners in another square = triangulated transformation.
    Sadly, those tiny lines in the sketch are killing my computer right now, LOL...
    2003-02
    1,819
    Quote Originally Posted by aaronrumple
    Ahhh.. second thing I've learned today. Amazing program it is, its a never ending exploration of different features and how far you can attempt to break them...
  1. 2014: Parametric Material in Geodesic Dome
    By nasab_5474906 in forum Revit - Conceptual Design Tools
    Last Post: 2014-07-01, 02:27 AM
  2. 2013: dome ornament
    By moshira_hassan in forum Revit Architecture - General
    Last Post: 2013-06-27, 04:02 PM
  3. 3D elliptical dome
    By kaarchs446756 in forum AutoCAD 3D (2007 and above)
    Last Post: 2011-06-07, 08:57 AM
  4. Ribbed Dome
    By arkonaft in forum Robot Structural Analysis
    Last Post: 2011-02-25, 09:43 PM
  5. Geodesic Dome with equilateral triangles
    By hugotavares6 in forum Revit - Conceptual Design Tools
    Last Post: 2010-10-17, 07:24 PM
