Results 1 to 7 of 7
Thread: Hiding Hatch patterns.
    Active Member treb's Avatar
    2002-07
    Toronto
    75
    Default Hiding Hatch patterns.
    I must be getting old, cause I can't seem to remember what the deal is with AutoCad 2000i and hiding hatches?
    Please see attached pic
    2001-03
    13,499
    Default Re: Hiding Hatch patterns.
    Hi
    Take a look at FillMode, below is from the AutoCAD Online Help File [F1] -
    Type: Integer
    Saved in: Drawing
    Initial value: 1
    Specifies whether hatches (including solid-fill), two-dimensional solids, wide polylines, are filled in.
    0 Objects are not filled
    1 Objects are filled
    Have a good one, Mike
    2002-07
    Toronto
    75
    first thing I tried Mike, no luck.
    Turns out that 2000i will not hide hatches, oh well, 2004 soon.
    2001-03
    13,499
    Hi
    Are you positive.... I've just tested here within AutoCAD 2000i and when FillMode = 0 Hatch Patterns are not displayed (you have to do a Regen or RegenAll to see results).
    2002-07
    Toronto
    75
    have a look at the attachment.
    Fillmode only controls if the hatch is on or not.
    Im stumped.
    2001-03
    13,499
    Hi
    Ok! now I see what you're after (I think), you want to hide part of a Hatch Pattern behind a Face/Surface.
    If you create your Objects using Solids, 3D Faces, Meshes, Regions etc you can then use the ._Hide command to hide/remove Hatch Patterns that are behind Faces/Surfaces (for an example refer to attached DWG file).
    2002-07
    Toronto
    75
    I think my drawing has gone corrupt, cause if I paste the model into a fresh drawing, it hides fine.
    My computer and AutoCad, is very unstable, does lots of interestsing stuff.
    Thanx Mike
  1. Hiding Hatch Pattern
    By huntbh in forum AutoCAD Customization
    Last Post: 2009-04-09, 05:27 PM
  2. Replies: 5
    Last Post: 2008-03-16, 07:00 AM
  3. Phasing and hiding surface patterns
    By kimheaver in forum Revit Architecture - General
    Last Post: 2007-07-06, 05:53 PM
  4. New Hatch Patterns
    By Clyne Curtis in forum Revit Architecture - General
    Last Post: 2006-05-26, 01:51 PM
  5. Fill Patterns not hiding
    By Joef in forum Revit Architecture - General
    Last Post: 2004-05-04, 03:03 AM
