Hi Binu,
If your schematic symbol is a block (and I'm assuming it is) the procedure is pretty simple.
NOTE: If you only need the device in your current drawing you can do the following procedure in that drawing. However, if you would like to use the device(s) in future drawings you will need to add it to the appropriate device drawing in your content folder.
I WOULD STRONGLY RECOMMEND BACKING UP THIS FILE BEFORE MODIFYING IT.
Here's the procedure:
- First if you would like the device to display differently in different views you will need to create block(s) for these views. I typically use a symbol block for top and bottom views and a 3D block for all other views.
- Go to FORMAT - Style Manager - Electrical Objects - Device Styles and click New Style
- On the General tab add the name you would like to call the device
- On the Design Rules tab pick the type of device, add a layer key and set how you would like the wire to cleanup.
- On the views tab Add a view called Plan, Pick your schematic view block on the view block pull down, select plan in the display representation, choose top and bottom on the view directions and click Use Annotation Scaling under scale.
- If you created a 3D block create a second view called Model, Pick your 3D block, select model in the display representation, choose everything but top and bottom, and don't check the Use Annotation Scale.
- On the Connectors tab, click add a connector and fill in the information for the connector.
- Finally, you can add a classification if you like and change the way the object is displayed.
It sounds like a lot of work but it's really pretty simple once you get the hang of it.
Hope this helps.
