Results 1 to 8 of 8
Thread: Moving Text Objects relative to base point as other Objects are moved / scaled
    I could stop if I wanted to William Troeak's Avatar
    2005-12
    standing @ the crossroads
    240
    Default Moving Text Objects relative to base point as other Objects are moved / scaled
    For all the Dynamic blocks that i have built and all the possible ones that have have yet to build there is one huge thing that I can not figure out.
    When I have a block lets say a detail box and i want to have the lower right hand corner be my base point and then have text in the upper left corner, how can i resize the box and have the text also move with it. I have tried using a move parameter but it still does not want to work. I have also tried setting it up with a visibility parameter but then i will end up with multiple strings of text.
    William Troeak
    Technical Specialist, Architecture
    US CAD
    Revit Architecture/BIM Instructor
    Long Beach City College
    2001-03
    13,499
    Default Re: Moving Text Objects relative to base point as other Objects are moved / scaled
    Hi Will
    Please note I have *moved* this thread from the AutoCAD 2007 General forum to this one, as I feel this particular forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Manager
    Dynamic Blockhead Mod Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    Quote Originally Posted by troeakwj
    sounds like you want Mtext in a box? Sorry, but it won't happen in a 'true' DB. I've done something similar tho, created a block that's exploded upon insertion that has a DB box (w/ one grip for stretching the corner thats opp. the text base) around an Mtext entity. It works pretty slick. I can post the note box when i get to work... if i remember...
    S&D DB Sharing Forum
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    6,836
    Could you post a sample of what you are trying to do? Is the text supposed to be editable?
    AUGI Addict .chad's Avatar
    2006-04
    is it lunch time yet?
    1,124
    Quote Originally Posted by Chris.N
    someone posted a way to do that a while back. the text sat in a rectangle that adjusted itself according to the text. im not sure if it was in tips & tricks or hot news, or somewhere else though.
    This aggression will not stand. Man.
    100 Club r424andy's Avatar
    2006-01
    In this Chair
    170
    here is a simple version of what he seemed to be looking for (if you take a literal interpatation of his question)
    AUGI Addict Mr Cory's Avatar
    2007-01
    Under a Rock over there
    1,006
    Why not use a table that has 1 row and 1 column, the box is asso to the text
    2001-12
    Rochester, MN
    2,561
    Quote Originally Posted by coryv
    can the, is the text MTEXT type?
  1. Base Point Keeps Moving
    By mark.195407 in forum AutoCAD General
    Last Post: 2009-04-21, 11:42 AM
  2. Sort an array of text objects by their X and Y insertion point values
    By danderson.71652 in forum VBA/COM Interop
    Last Post: 2006-06-28, 03:39 PM
  3. Inserting into Paperspace, I get different scaled Objects.
    By sherflor in forum AutoCAD General
    Last Post: 2006-05-08, 08:26 PM
  4. Editing a Scaled Block with AEC Objects Error
    By renee in forum ACA General
    Last Post: 2006-01-09, 05:14 PM
