Thread: dimension tick mark
    2005-05
    66
    Default dimension tick mark
    hi,
    i want to know if we can change the dimension tick mark from what exists to anything smaller.
    is it possible...help please.
    2006-09
    Johannesburg South Africa
    46
    Default Re: dimension tick mark
    Don't know if this is what you are looking for but if you select the dimension and go to its properties under edit new you can apply changes you want to make to the dimension style
    2005-05
    66
    we can change the type from just what exists...but,can we create a new tick mark please?
    any work around that any one knows??
    2003-04
    Chino, CA
    4,756
    What type of tick mark do you want? There are many that come with Revit, and all are modifiable under Settings>Annotations>Arrowheads
    2005-05
    66
    thanx a ton...
    i wonder how i had missed out on something so obvious and simple.
    thank you again.
  1. 2012: Dimension tick mark lineweight
    By damon.sidel in forum Revit Architecture - General
    Last Post: 2012-04-27, 08:18 PM
  2. Dimension tick mark
    By fjtdogeno in forum Revit Architecture - General
    Last Post: 2011-10-05, 03:26 PM
  3. Dimension Tick Mark Direction
    By Dezi in forum Revit Structure - General
    Last Post: 2009-09-17, 02:48 PM
  4. Dimension Line Tick Mark question:
    By SCShell in forum Revit Architecture - General
    Last Post: 2005-08-19, 02:22 PM
