Results 1 to 10 of 10
Thread: Detach Image IF it exists
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    2,020
    Default Detach Image IF it exists
    We have an image in many of our drawings that is a remnant of on old title block. I want to put something in my Acaddoc.lsp to detach the image if it exists. My only problem is I don't know how to determine if it exists.
    I put the following line in my Acaddoc.lsp:
    (command "-image" "d" "BW_JR_FORMAT_B")
    That works fine if the image exist but crashes if it does not. Well OK it doesn't "crash" but it displays the message Unknown command "BW_JR_FORMAT_B".
    How would I search the drawing to see if the image exists and how would I put the above line of code into an IF statement?
    Edit: If there is a better way to accomplish my goal I am more than willing to listen.
    2005-08
    1,043
    Default Re: Detach Image IF it exists
    How comfortable are you with lisp and dictionaries? That is the way I would do it. Step through the 'ACAD_IMAGE_DICT' and see if your image is there, if so, erase it from the dictionary.
    2002-04
    Colorado
    2,020
    Unfortunately I am not very familiar with dictionaries or lisp for that matter. I'm what I call a lisp hack.
    When I have more time I will do some research on accessing the dictionaries.
    AUGI Addict Railrose's Avatar
    Abilene, TX
    1,181
    Quote Originally Posted by jpaulsen
    You can also do a CTRL + A to select everything, then CTRL + 1 to open the properties box. At the top left, is a pulldown. Click the arrow, & it will give you the option for Raster Image, if one exists. Can be slow to run on huge drawings, but is a quick & dirty way to see what is in the drawing file.
    Give people a job worth doing, the tools to do it, recognition of a job well done & get out of the way.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,103
    Quote Originally Posted by drafter29
    Jane,
    That is a good tip. However, Jeff is looking for an automated approach to removing the image.
    2002-01
    jUSt Here (a lot)
    9,103
    Jeff,
    Maybe the links in this post can help you on your journey to learning dictionaries.
    2015-08
    263
    Hi Jeff,
    This code won't display the irritating "Unknown command..." string.
    (command "-image" "d")
    (if (= (getvar "cmdactive") 1)
      (command "BW_JR_FORMAT_B")
      (princ "\nNo images found in this drawing.")
    You may delete (princ "\nNo images found in this drawing.") if you don't want to see any prompt.
    Regards,
    Abdul Huck
    2002-04
    Colorado
    2,020
    I ended up using the code posted by R.K. McSwain in this thread:
    http://discussion.autodesk.com/threa...sageID=5498183
    2004-07
    Detroit Michigan
    2,508
    Is there a way to detach all images?
    2002-04
    Colorado
    2,020
    Here is a modified version of Abdul's code that seems to work.
    (defun c:test()
    	(command "*")
    (princ)
  1. 2015: FAMILY ALREADY EXISTS
    By gordolake in forum Revit Architecture - General
    Last Post: 2014-08-26, 11:29 PM
  2. test if level exists
    By sfaust in forum Revit - API
    Last Post: 2012-01-11, 04:38 PM
  3. LISP to detach all XREF,PDF,IMAGE,ALL UNDERLAYS
    By sweichel in forum AutoLISP
    Last Post: 2011-07-05, 02:56 PM
  4. .png image will not detach!
    By Openwheeler in forum AutoCAD Map 3D - General
    Last Post: 2010-03-10, 04:39 PM
  5. napkin sketch still exists???
    By ccook.135811 in forum ACA General
    Last Post: 2007-10-16, 03:38 PM
