I too got the filer error in block insertion. I had this code at the top of the program:
Dim IssueBlock As String
IssueBlock = "c:\qp\QP_Issue.dwg"
Much further down in the code I had:
Set IssueReference = .PaperSpace.InsertBlock(Ipt, IssueBlock, 1#, 1#, 1#, 0#)
This code was written for AC2005. The program adds issue dates to a drawing set. Interestingly, if the block was already in the sheet (previous issues) the insert worked. It was only those sheets that were being issued for the first time that failed. When I entered debug and checked the value of IssueBlock, it was not the string as assigned in the assigment statement (above)!!!!!
I moved the assignment directly over the InsertBlock and it worked.
IssueReference.Update
I think this ought to be a high priority fix at Autodesk.
