Thread: DST files in ABS2007
    100 Club finney13's Avatar
    2005-03
    Brentwood, TN
    134
    Default DST files
    When I try to delete a .dst file via Windows Explorer, it allows me tro delete the file and then pops right back up.
    I have tried removing all the drawings from the sheet set. I have tried deleting the drawings that are being referenced by the sheet set. Makes no difference.
    Anyone know how I can delete this file?
    (It should not be a permissions problem)
    2002-09
    Madison, WI
    4,445
    Default Re: DST files in ABS2007
    Before you try to delete it, make sure all users have closed out of ABS and exited the program. Is the .dst file corrupt or something, Is that why you want to delete it?
    Dave Peterson
    Acad 2012 - Revit Structure 2013 - Z220 - Win 7 64 - i7-3770 3.4GHz 32GB Ram
    "The more you know, the less you know, because the more you know you don't know". --M. Lin
    2005-03
    Brentwood, TN
    134
    Actually, a Sheet Set was created with the wrong name, tried to change the name and it created a second Sheet Set. I was trying to delete the orignal and it would not let me.
    2002-09
    Madison, WI
    4,445
    Well a possible option (I've never done it but it could work in theory) is to change the extension type. Try adding a .old to the end of the file name. "sheetset.dst.old". If you can confuse ABS into thinking the file isn't there it will ask you if you'd like to re-create it.
    Dave Peterson
    2005-03
    Brentwood, TN
    134
    I meant to post back the renaming the file extension works great.
    Thanks for the idea.
  1. AMEP2008 vs. ABS2007.1
    By finney13 in forum AMEP General
    Last Post: 2007-12-10, 06:34 PM
  2. Formula Help in ABS2007.1
    By stelthorst in forum Style Management
    Last Post: 2007-04-16, 11:22 PM
  3. MvParts in ABS2007
    By ordengate in forum Parts Builder
    Last Post: 2007-03-31, 12:36 AM
  4. ABS2007 Property set help
    Last Post: 2007-03-27, 12:11 PM
  5. Updating an MvPart in ABS2007
    By finney13 in forum Parts Builder
    Last Post: 2007-02-28, 05:06 AM
