Results 1 to 9 of 9
Thread: Civil 3D - Call Point Number command from Zoom Center
    2004-11
    Somewhere close to hell
    228
    Question Civil 3D - Call Point Number command from Zoom Center
    In civil3d the user has the ability to select a given point and zoom to it, is there a way to call a transparent command Ex: 'pn "Point Number" from the zoom center command?
    (defun c:zp ()
    (setq pt1 (command "'pn"))
    (command "zoom" "c" pt1)
    (princ)
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,105
    Default Re: Civil 3D - Call Point Number command from Zoom Center
    Quote Originally Posted by rad.77676
    (defun c:zp ()
    (princ)
    Have you tried the Zoom Object command? If you can get the entity name from the "pn" command, the Zoom with the Object option should provide you what you want.
    2004-11
    228
    The pn command prompts user for point number, it only returns what you give it.
    The issue is how to call the transparent 'PN command during to zoom command?
    Any ideas?
    2003-11
    277
    Hi rad,
    I'm not yet understanding,what are you looking for.
    but here my code to check as you want
    (defun c:zp (/ ss sse etyp sp mag)
      (if
        (setq ss (car (entsel "\nSelect an object point")))
        (progn
          (setq sse (entget ss))
          (setq etyp (cdr (assoc 0 sse)))
          (if
    	(= etyp "POINT")
    	(progn
    	  (setq sp (cdr (assoc 10 sse)))
    	  (setq mag 100)
    	  (command "_zoom" "c" sp mag "")
    	  )                                ; progn
    	(alert "\nThis object is not Point")
    	)                                  ; if
          )                                    ; progn
        (alert "\nInvalid selected object,please try again")
        )                                      ; if
      (princ)
    (defun c:zp ()
    (princ)
    2015-12
    Central Oregon
    591
    Hi rad,
    Here's a lisp that does what you need. The ActiveX ZoomCenter method allows for a magnification value which I have hardcoded to be 10x the current value.
    (defun c:zoom2pt (/ aeccdoc appstr point points pt pt# vrsn)
      (setq vrsn (vlax-product-key))
      (cond ((vl-string-search "R16.2" vrsn)(setq appstr "3.0"))
    	((vl-string-search "R17.0" vrsn)(setq appstr "4.0"))
    	(t (alert "This version of C3D not supported!"))
      (if (and appstr
    	   (or *acad*
    	       (setq *acad* (vlax-get-acad-object))
    	   (or *AeccApp*
    	       (setq *AeccApp* (vla-getinterfaceobject *acad*
    				 (strcat "AeccXUiLand.AeccApplication." appstr)))
    	   (setq aeccdoc (vlax-get *AeccApp* 'ActiveDocument))
    	   (setq pt# (getint "\nZoom to point #?: "))
    	   (setq points (vlax-get aeccdoc 'points))
    	   (not (vl-catch-all-error-p
    		  (vl-catch-all-apply
    		    '(lambda ()
    		       (setq point (vlax-invoke points 'find pt#))
        (progn
          (setq pt (vlax-get point 'location))
          (setq vsize (getvar "viewsize"))
          (vlax-invoke *acad* 'zoomcenter pt (/ vsize 10.0))
          (vlax-release-object points)
          (vlax-release-object aeccdoc)
      (princ)
    HTH,
    Jeff
    2004-11
    228
    Talking Re: Civil 3D - Call Point Number command from Zoom Center
    Works like a charm!
    Thanks Jeff
    2004-11
    228
    Question Re: Civil 3D - Call Point Number command from Zoom Center
    Jeff,
    Rather than basing the zoom factor on the viewsize is there a way to make the zoom factor the same every time?
    Rob
    2004-11
    228
    Jeff,
    I just removed (/ vsize 10.0) and replaced with vsize so the view remains constant from point to point.
    Thanks for your help!
    Rob
    2002-01
    jUSt Here (a lot)
    9,105
    Jeff,
    Rob
    Zoom to the size you want. Extract the "VIEWSIZE" system variable. Place that size in place of the formula (/ vsize 10.0) in the following line from Jeff's code.
  1. Work Request Management (call center?)
    By Wanderer in forum Facilities Management In Practice
    Last Post: 2015-07-07, 06:03 PM
  2. 2014: Control how far Zoom command will zoom out?
    By mbrandt5 in forum AutoCAD General
    Last Post: 2015-05-21, 05:42 PM
  3. Call out sheet number on View Lable Title
    By joforman in forum AutoCAD Sheet Set Manager
    Last Post: 2012-01-11, 06:10 PM
  4. Replies: 10
    Last Post: 2007-03-23, 01:50 AM
  5. Performance issues - Slow Zoom when using the Zoom command
    By gsmith.29521 in forum AutoCAD General
    Last Post: 2005-11-01, 08:53 PM
