Results 1 to 10 of 11
Thread: Erasing everything outside a boundary
    2016-01
    43
    Default Erasing everything outside a boundary
    I know that AutoCAD has the extreme trim command which enables you to trim everything either inside or outside a boundary line.
    Has anyone put together a routine that will delete everything either inside or outside a specified boundary line?
    The Silent Type
    2015-12
    383
    Default Re: Erasing everything outside a boundary
    Simple way
    use "erase" "all" "remove" and then window the objects you do not want erased
    2016-01
    43
    In a perfect world...with perfect boundaries...
    But...
    This isn't a perfect world...and my boundary lines are all over the place...
    Thanks for the help
    The Silent Type
    2015-12
    383
    have you tried using
    "erase" "All" "remove" "f"
    2006-02
    Red face Re: Erasing everything outside a boundary
    Please pardon my ignorance, I'm attempting to overcome it. I think Stephen and I are looking for the same thing.
    I am very much in need of the "extreme trim command which enables you to trim everything either inside a boundary line." I don't know of this command.
    The best that I can do is laboriously apply the xclip command for blocks & xrefs, then trim (standard version) for everything that crosses the boundary, and then erase everything else. [Working strictly 2D in this discussion] I tried this in both 2008 and 2004 using an existing drawing. I didn't understand the erase-all...f suggestion. If I use the erase command, the selected objects are completely removed; "erase" does not give the option for a boundary to slice though objects.
    Quote Originally Posted by Stephen.Walz
    2007-03
    57
    try it
    ;Required Express tools
    ;OutSide Contour Delete with Extrim
    (defun C:OCD (  / en ss lst ssall bbox)
    (vl-load-com)
      (if (and (setq en (car(entsel "\nSelect contour (polyline): ")))
               (wcmatch (cdr(assoc 0 (entget en))) "*POLYLINE"))
        (progn
          (setq bbox (ACET-ENT-GEOMEXTENTS en))
          (setq bbox (mapcar '(lambda(x)(trans x 0 1)) bbox))
          (setq lst (ACET-GEOM-OBJECT-POINT-LIST en 1e-3))
          (ACET-SS-ZOOM-EXTENTS (ACET-LIST-TO-SS (list en)))
          (command "_.Zoom" "0.95x")
          (if (null etrim)(load "extrim.lsp"))
          (etrim en (polar
                      (car bbox)
                      (angle (car bbox)(cadr bbox))
                      (* (distance (car bbox)(cadr bbox)) 1.1)))
          (if (and
                (setq ss (ssget "_CP" lst))
                (setq ssall (ssget "_X" (list (assoc 410 (entget en)))))
            (progn
              (setq lst (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))))
              (foreach e1 lst (ssdel e1 ssall))
              (ACET-SS-ENTDEL ssall)
    (princ "\nType OCD")
    2005-08
    378
    Cool Re: Erasing everything outside a boundary
    azarko,
    Can you please have a quick look t this and see where the error is ?
    I used your routine and tried to have it allow the user to draw the boundary and then erase it, though somethings not right.
    Routine below:
    ;Erases Everything OutSide Contour Delete
    (defun C:OCD (/ en ss lst ssall bbox)
    (vl-load-com)
    (setq oldclayer (getvar "clayer")
    oldcecolor (getvar "cecolor")
    (command "_clayer" "0")
    (command "_cecolor" "20")
    (command "plinewid" 100)
    (command "_pline")
    (while (= (getvar "cmdactive") 1) (command pause))
    (setq en (entlast)
    (if
    (wcmatch (cdr (assoc 0 (entget en))) "*POLYLINE")
    (progn
    (setq bbox (mapcar '(lambda (x) (trans x 0 1)) bbox))
    (if
    (null etrim)
    (load "extrim.lsp")
    (etrim en
    (polar
    (car bbox)
    (angle (car bbox) (cadr bbox))
    (* (distance (car bbox) (cadr bbox)) 1.1)
    (if (and
    (progn
    (command "_erase" en "")
    (setvar "clayer" oldclayer)
    (setvar "cecolor" oldcecolor)
    (command "plinewid" 0)
    Thank you
    Stephen
    2003-11
    Dublin, Ireland.
    151
    Here's one I came across a few years ago.
    Hope this helps
    John
    2003-11
    Dublin, Ireland.
    151
    Sorry, just realised it only does rectangles.............
    Not much help then.
    2007-03
    57
    >stephen.coff
    ;Erases Everything OutSide Contour Delete with Extrim
    (defun C:OCD (/ en ss lst ssall bbox *error* oldclayer oldcecolor opw)
    (defun *error* (msg)(princ msg)
      (setvar "plinewid" opw)(setvar "cecolor" oldcecolor)
      (vla-EndUndoMark (vla-get-activedocument (vlax-get-acad-object))))
    (vl-load-com)
          opw (getvar "plinewid")
    (vla-StartUndoMark (vla-get-activedocument (vlax-get-acad-object)))
    (setvar "clayer" "0")
    (setvar "cecolor" "20")
    (setvar "plinewid" 100)(setvar "cmdecho" 1)
    (command "_pline")
    (while (> (getvar "CMDACTIVE") 0)(command pause))
    (setq en (entlast))
    (if
    (progn
    (if
    (null etrim)
    (load "extrim.lsp")
    (etrim en
    (polar
    (car bbox)
    (if (and
    (progn
    (princ)
    Your error here: (setq en (entlast)
    It is necessary: (setq en (entlast))
  1. Replies: 0
    Last Post: 2012-03-29, 05:35 AM
  2. When erasing hatch boundary goes also.
    By jsnow in forum AutoCAD General
    Last Post: 2007-01-10, 08:17 AM
  3. erasing titles
    By tect75 in forum Revit Architecture - General
    Last Post: 2006-03-20, 03:28 PM
  4. Erasing a selection set name
    By Coolmo in forum VBA/COM Interop
    Last Post: 2004-08-26, 09:17 PM
  5. Phase Erasing?
    By gregcashen in forum Revit Architecture - General
    Last Post: 2003-09-18, 07:21 AM
