Hello,
I am trying to adapt the code to search polylines inside polylines that are crossing its limits and then trim that pieces off. But, for some reason isn't working out.
Help!
; Trim selected objects outside a closed poly -
;(requires Express Tools!)
; adapted Maio 19 by Zucco
; original file
(vl-load-com)
(defun c:Trim_Outer ()
(setq cmde (getvar "CMDECHO"))
(setvar "CMDECHO" 0)
(command "_UNDO" "_Group")
(initget 1 "ED TEMP FRONT")
(setq ED_layer (getkword "\nEscolha a Classe da edificação [ED/TEMP/FRONT]: "))
(if (= ED_layer "ED")
(setq ED_layer "ED_TEMP")
(if (= ED_layer "TEMP")
(setq ED_layer "UP_TEMP")
(if (= ED_layer "FRONT")
(setq ED_layer "UP_FRONT")
;(setq entLR (car (entsel "\nSelect Limite ou borda: ")))
;(setq ssLotes (ssget "_CP" (mapcar 'cdr (vl-remove-if-not '(lambda (item) (= (car item) 10)) (entget entLR)))
; (list (cons 0 "*POLYLINE" )(cons 8 "*LOTES_FISICOS" )(cons 410 "Model"))))
(setq ssLotes (ssget "_X" (list (cons 0 "*POLYLINE" )(cons 8 "*LOTES_FISICOS*")(cons 410 "Model"))))
(if (not (equal ssLotes nil)) (setq LTqtd (sslength ssLotes)) (setq LTqtd 0))
(while (> (setq LTqtd (1- LTqtd)) -1)
(setq entLT (ssname ssLotes LTqtd))
;(setq objLT (vlax-ename->vla-object entLT))
(setq cbox (ACET-ENT-GEOMEXTENTS entLT))
(setq cbox (mapcar '(lambda(x)(trans x 0 1)) cbox))
(setq lst (ACET-GEOM-OBJECT-POINT-LIST entLT 1e-4))
(ACET-SS-ZOOM-EXTENTS (ACET-LIST-TO-SS (list entLT)))
(command "_.ZOOM" "0.95x")
(if (null etrim)
(load "extrim.lsp")
(etrim entLT (polar (car cbox)
(angle (car cbox)(cadr cbox))
(* (distance (car cbox)(cadr cbox)) 1.1)))
(setq e1 nil
ssEdif nil)
(if (and
(setq ssBord (ssget "_CP" lst
(list (cons 0 "*POLYLINE")(cons 8 ED_layer)(cons 410 "Model")) ))
(setq ssEdif (ssget "_CP" (mapcar 'cdr (vl-remove-if-not '(lambda (item) (= (car item) 10)) (entget entLT)))
(list (cons 0 "*POLYLINE")(cons 8 ED_layer)(cons 410 "Model"))))
(progn
(setq lst (vl-remove-if 'listp (mapcar 'cadr (ssnamex ssBord))))
(foreach e1 lst
(ssdel e1 ssEdif) ; Deletes an object (entity) from a selection set
(ACET-SS-ENTDEL ssEdif)
(list (cons 0 "*POLYLINE")(cons 8 ED_layer)(cons 70 0)(cons 410 "Model"))))
(if (not (equal ssEdif nil)) (setq EDqtd (sslength ssEdif)) (setq EDqtd 0))
(while (> (setq EDqtd (1- EDqtd)) -1)
(setq entED (ssname ssEdif EDqtd))
(setq objED (vlax-ename->vla-object entED))
(vlax-put-property objED 'Closed 1)
) ; end while
)) ; end progn & if
) ;end while
(setvar "cmddia" 1)
(setvar 'osmode os)
(setvar "cmdecho" 1)
(princ)
(gc)
) ; end defun
Thanks in advance.
