Results 1 to 10 of 10
Thread: An easy way to draw a 3d roof in AutoCAD 2004...2007
    Português Forum Moderator Brogueira-CADptbr's Avatar
    2003-08
    Porto-Portugal
    416
    3 members found this post helpful.
    Default 2D Plant, Sections and Elevations from a 3d roof, more easily, in AutoCAD 2004...2007
    Draw a closed polyline of the roof contour. (see picture)
    Note: Measures are in meters.
    Put it in an isometric view.
    Extrude the polyline as text in the picture
    If you want a roof with an inclination of 15 degrees you must introduce in the taper angle 90 –15 = 75 .
    Now we need to close the top of the roof. How!
    Using the Solids Editing toolbar we will chose Offset Faces.
    And then we will proceed as in the following picture
    We can get one of these results…
    Or to Offset faces only 1 meter and then the result will be this
    Use your imagination to explore the potential of AutoCAD.
    You can find this Tip the in Portuguese in the AUGI's Portuguese Forum
    Pode encontrar esta Dica em Português no Forum em Português do AUGI
    http://forums.augi.com/showthread.php?t=52372
    If necessary I can explain how to obtain the 2D from the 3D Model using the SOLVIEW and SOLDRAW commands.
    Last edited by augi574259; 2007-02-08 at 10:33 PM. Reason: Better description for the Tip
    13,625
    Thumbs up Re: An easy way to draw a 3d roof in AutoCAD 2004...2007
    Hi João
    Very nice
    Mike
    All AUGI, all the time bbapties's Avatar
    2003-12
    Palm Harbor, FL
    537
    Default Re: An easy way to draw a 3d roof in AutoCAD 2004...2007
    great tip!
    Active Member davidmatyas's Avatar
    2005-01
    72
    Looks like a great idea!!
    David M. Matyas
    Matyas_COMP_Services
    I could stop if I wanted to ronie_ernanto's Avatar
    2006-11
    Jauh di Sidoarjo sana (Indonesia)
    312
    Good tips...
    Now I don't only do home interior, but also exterior - including roof. I will try your tips....
    2004-12
    15
    Exclamation Re: An easy way to draw a 3d roof in AutoCAD 2004...2007
    What am I doing wrong here?
    I tried to create this roof, but when I extrude the inner corners keep having a radius
    is there a setvar I need to change.
    I am using Autocad 2005.
    Regards,
    Martin
    2003-08
    Porto-Portugal
    416
    Hi Martin,
    Would you please send me a picture of what you got or your dwg file to see what's wrong?
    Frankly I do not understand what do you mean with "...the inner corners keep having a radius..." .
    I'm an AutoCAD Instructor and I teach this tip since the AutoCAD 2004 and never gave a problem.
    Hoping to hear from you by return.
    2004-12
    15
    Hi, Brogueira-CADptbr
    Here is the file, This is after the ext!!
    Thankyou
    2003-08
    Porto-Portugal
    416
    Hi Martin,
    Thank you for sending the file. I did not understand why the round corners appear?
    The only possibility for this is to have a very small fillet radius in the polyline (so small that you are unable to see it).
    Try to do this with Lines and create a Region instead of the Polyline and Extrude that Region.
    Hoping to have been of help.
    2004-05
    2
    Wink Re: An easy way to draw a 3d roof in AutoCAD 2004...2007
    Wonderful method.
    What a easy!
    thanks,
    Khin Soe
  1. Replies: 5
    Last Post: 2007-05-04, 03:49 PM
  2. Replies: 6
    Last Post: 2007-03-27, 03:06 PM
  3. Replies: 21
    Last Post: 2006-12-16, 05:44 PM
  4. Make Plotting easy in AutoCAD LT 2007
    By jaredf in forum AutoCAD LT - General
    Last Post: 2006-07-18, 12:09 AM
  5. Cost of upgrading from AutoCAD 2004 to AutoCAD 2007
    By SteveChestnut in forum CAD Management - General
    Last Post: 2006-05-25, 10:43 AM
