very often it becomes hard to locate the view you wanna activate, starting a viewname with a code helps, but not enough...
everyone likes this; (both on views AND Sheets)
add a projectparameter "FOLDER" [type=text / instance-based / NoMatterWhatGroup] to Views (and/or Drawing Sheets)
next; setup a new ProjectBrowser type:
1: Group by Family
2: Then by FOLDER
4: Sort by Family and Type
@first there will be shown ??? as a defaultname for the FOLDER
you can select all views (w shift) in a category, rightclick > properties and alter the FOLDER name
the FOLDER parameter will be shown; and ofcourse you can do it per view...
same for SheetBrowser;
1. Group by FOLDER
4. Sort by Sheet number
it helps you reducing the proj.browser listlength and go faster to the desired view
you can by the way also schedule this parameter although it is not a shared param.
Laurens
Itannex (NL)
