Page 1 of 6 12345 ... LastLast
Results 1 to 10 of 52
Thread: Chain Action-Stretch with Array
    2006-12
    Big "D"
    3,709
    Default Chain Action-Stretch with Array
    Okay, this is driving me crazy.
    I have a lube center with 10' bay doors and 4' columns between the doors. I am trying to stretch the block in 14' increment and have the column and door array. That way I can easily go from a 4 bay, to a 5 bay, to a 6 bay, etc. Problem is, it's stretching fine, but the column and door won't array. I've looked at it every way possible, and it looks to be correct in the block setup. Any ideas?
    Why is it called common sense when it is so rare?
    RevitForum.org
    AUGI Addict Mr Cory's Avatar
    2007-01
    Under a Rock over there
    1,006
    Default Re: Chain Action-Stretch with Array
    Is it possible to post a drawing with the block in it?
    Dynamic Blockhead Mod Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    Quote Originally Posted by dzatto
    with arraying, there shouldn't be any 'chaining' required. is it possible that you have a plethora of parameters present?
    Sometimes, i get lost in my own thoughts and need to ask directions to find my way back.
    S&D DB Sharing Forum
    2006-12
    Big "D"
    3,709
    Quote Originally Posted by Chris.N
    Not with a basic array command, but I need to stretch the building, then have the column and door array at the same time. There was a white paper on it that I found on this thread, and they did it with a metal plate with a hole in the center. When they stretched the plate, the hole arrayed automatically. I tried to do mine the same way, but I can't get it to work.
    I could just have 2 grips, one to stretch, the other to array, but one is so much better!!
    RevitForum.org
    100 Club r424andy's Avatar
    2006-01
    In this Chair
    170
    The issue is that you teh entire array parameter inside the stretch crossing window. One end point needs to be outside the crossing window, otherwise you are just moveing the array parameter.
    2001-12
    Rochester, MN
    2,561
    just as i suspected, you had parameter plethoritis....
    btw, i had to re-do the stretch cuz it was grabbing the 14' grip funny.... ~shrug~
    2001-12
    Rochester, MN
    2,561
    Quote Originally Posted by r424andy
    yeah, that too.... (i fixed it in my fix, check it out)
    2006-12
    Big "D"
    3,709
    ahhhhhh okay. I could swore the tutorial said to pick the entire array in the window. ~shrug~
    As long as it works. Thanks guys!, You saved me from throwing my PC outta the window.
    RevitForum.org
    2006-12
    Big "D"
    3,709
    So, you did an array paramter, with an array action, then only a stretch action (without a stretch parameter) and included on one grip of the array parameter in it?
    Is there any way to stretch negative? In other words, the base block you have is a 4 bay, and the column width is 4'. How would I make it a 3 bay? I can't do what we just did and start with a 3 bay, because the column width by the stairs is 4.5', so if I arrayed that, all the columns would be 6" too long. Any suggestions?
    RevitForum.org
    2001-12
    Rochester, MN
    2,561
    in my class i stated that you can have as many 'actions' as you can cram onto a parameter as needed. you don't need separate parameters and actions doing the same thing....
    i'd use a vis state. no parameters shown for the 3 bay, but the 4 bay + option has all the toys available. would that work?
  1. 2011: AutoCAD Stretch Action Anomoly
    By chillme1 in forum Dynamic Blocks - Technical
    Last Post: 2012-02-22, 10:22 PM
  2. Can I Chain Linear Stretch and Visibility States?
    By chez_moody in forum Dynamic Blocks - Technical
    Last Post: 2010-11-09, 03:27 PM
  3. How to make rotate action grip move with stretch action
    By Mac Demer in forum Dynamic Blocks - Technical
    Last Post: 2009-07-23, 12:58 PM
  4. Dynamic Blocks Stretch Action Tip
    By hoffth in forum AutoCAD Tips & Tricks
    Last Post: 2009-07-08, 02:20 PM
  5. Rotate and Stretch Action
    By MikeM4OSU in forum Dynamic Blocks - Technical
    Last Post: 2007-06-19, 07:44 PM
