You, sir, are a feakin' genius. Either that or you're just really good with DB's.Originally Posted by Mr Cory
I'm starting to understand these better now. Just don' t know all the tips and tricks(and no no's)
Any idea why it won't array?
first, why is the file so huge?Originally Posted by dzatto
it helps downloading if they're smaller.
why isn't either your Base Point Parameter or your Rotate parameter at '0,0'? it helps most trouble-shooting issues if you at least keep 0,0 in the general vicinity of the geometry.
if you can deal with 2 parameters, i'd use another one to array the symbol.
i quickly thought of a solution using a lookup, but also figure it would take me at least 30 minutes to get it to work as needed....
S&D DB Sharing Forum
Not quite sure if this is what your after but have a look
Opps sorry forgot to add the move and stretch to the flip and rotate
Hmm, I'm not sure why it is so huge. It's just a few lines and DB commands.Originally Posted by Chris.N
I have a drawing called dynamic blocks where I create them, so thats why its not at 0,0. I just saved this particular block out of the main drawing. I really don't want to do a lookup because I stll need to add a few vis states. Sometime the handicap parking has curbs around it, sometimes it doesn't. So I was going to do vis states to take care of that. I guess I could do 2 parameters, but one just seemed easier. Now that it doesn't work with one, I'd like to figure out why just so I know!!!!
Thanks for the input.
Almost. Why did you have to use the move action instead of the array? I thought that would just move it. I know there's different ways to do it, but now I'm determined to make this work!!!! It's turning into a mission. Thanks for the help. I'll let ya know if I figure something else out.Originally Posted by Mr Cory
your array doesn't work because the parameter controlling it doesn't stretch the required distance to kick it into gear. you have a base parameter length of 16' with an option of 24'. if your option was to include 32', then the 16' array would work, but of course that's not what you want....Originally Posted by dzatto
Yeah, I noticed that. There's room for it to "fit" in there. I mean, I understand why it's not kicking in the array parameter, but there has to be a way to do this. I'm not giving up yet!!!!!Originally Posted by Chris.N
I suppose I could just do it with vis states. Either double or single, with or without curbing. 4 options won't be too bad. I'll never go over 2 spaces anyway since I never have more than 50 parking spaces.
Is there any way to have 2 insertion points? I would like to have one on the corner of the parking space, then one 4' above it. When I put the handicap space in front of a lube center, there is no sidewalk, we just leave a 4' space between the striping and the door.
yes, you can have your parameter nodes act as optional base points by hitting your 'Ctrl' key. i know i talk about this in my atp as well. the property that controls wether it can be used or not is called 'cycling'Originally Posted by dzatto
