Results 1 to 10 of 14
Thread: Batch convert DXF files to DWG files
    I could stop if I wanted to Doodlemusmaximus's Avatar
    2005-04
    RAT HALL
    298
    Default Batch convert DXF files to DWG files
    hi there folks
    is there any one out there who knows anyway or program/bolt on that will batch convert DXF files into Dwg files. We've been sent some 200 odd OS tiles that need to be converted and if they can be done en mass it would be a great help and time saving exercise.
    Cheers
    B-)
    I could stop if I wanted to michael.12445's Avatar
    2001-03
    350
    Default Re: Batch convert DXF files to DWG files
    You could write a script to run in AutoCAD, something like:
    OPEN
    FILENAME.DXF
    SAVE
    CLOSE
    OPEN
    With the above repeated once for every file. I often have to convert a batch of files from R2004 format to an earlier format, and that's what I do. I start with a text file made at the Windows command prompt, i.e.
    C:>cd filedirectory
    C:\filedirectory>dir *.dwg /b > C:\somefolder\batch.scr
    and then use a word processor on the batch.scr file to fill in the rest of the script using the word processor's search and replace functions.
    The problem is that all those DXF files you have need to be perfectly digestible by AutoCAD. The DXF format is not very rigorous, and AutoCAD is not very forgiving of variations. If it finds what it thinks is an irregularity, it will give you an error and refuse to import any of the file. So you should try a few random ones manually first to see if the script idea is viable.
    Michael Evans
    Togawa Smith Martin Residential, Inc.
    2005-04
    RAT HALL
    298
    Quote Originally Posted by michael.12445
    OPEN
    FILENAME.DXF
    SAVE
    CLOSE
    OPEN
    C:>cd filedirectory
    Michael Evans
    cheers for that I'll give it a shot. Hopefully they'll be a quick way of importing the dxf file using wild cards. I'll have to experiment, I must admit that I hadn't thought of that way
    13,656
    Hi
    Additionally, the couple of links found in the following post might prove helpful / useful...
    RE: How can I do a mass SaveAs to AutoCAD 2002?
    Have a good one, Mike
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,105
    Quote Originally Posted by Mike.Perry
    Hi
    Mike,
    Do you know if the Batch Drawing Converter from this thread, "AutoCAD chokes on script file", will convert dxf files to dwg?
    The DWG TrueConvert program does not mention opening DXF as an option.
    13,656
    Quote Originally Posted by Opie
    Mike,
    Hi
    Pass... as I no longer have access to that old Autodesk DWG Converter, nor can my memory stretch back that far.
    Regardless, the information presented in the other thread [ Mass convert DWGs to R12 DXF ] will definitely work, with a little alteration / tweaking.
    2002-01
    jUSt Here (a lot)
    9,105
    Hi
    Here is another Knowledge Base article on the subject. ID: TS67473 Batch convert DXF™ files to DWG files. It's a bit old but should also help.
    2015-08
    263
    ...and then use a word processor on the batch.scr file to fill in the rest of the script using the word processor's search and replace functions.
    Michael,
    Here is a small lisp code which I posted in AutoLisp forum to suite his requirement. First we have to edit the lisp file to accommodate our requirement, then run it and just browse the folder. It will create the script and run it.
    Quote Originally Posted by Beldin
    ...anyway or program/bolt on that will batch convert DXF files into Dwg files.
    Beldin, if you want me to modify to suite your requirement, please post the command sequences as per the version of your AutoCAD. You have to try this with "filedia" set to 0. For example:
    Filedia
    New
    acad.dwt
    dxfin
    c:\folder\filename.dxf
    qsave
    2004
    c:\folder\filename.dwg
    Regards,
    Abdul Huck
    2005-04
    RAT HALL
    298
    Quote Originally Posted by abdulhuck
    Michael,
    Filedia
    New
    acad.dwt
    dxfin
    c:folderfilename.dxf
    qsave
    2004
    c:folderfilename.dwg
    Regards,
    Abdul Huck
    Abdul
    Its quite simple really, all the files are in one place though there is about 7000 of them to be converted. I am running ABS 2007 but they all have to be saved down to 2004 format and left in the same folder. so I'm guessing that what you/vie posted above is pretty much what is really needed. I'll pull across the files to the C drive and let them go from there maybe overnight as I'm sure it'll take several hours to run through them all.
    If you would re-write the lisp to suit I would be grateful.
    Cheers
    B-)
    2015-08
    263
    I have updated the lisp file. You have to just browse to the folder where the dxf files are located. It should work normally, I tried it in AutoCAD 2005 only. Please let me know if there is any problem, preferably with a snip of the command prompt.
    Regards,
    AbdulHuck
  1. batch convert 2009 files to 2010
    By Kenny Gee in forum Revit Architecture - General
    Last Post: 2009-12-14, 08:09 AM
  2. Batch convert of dwg files in multiple folders
    By tonyisenhoff in forum DWG TrueView - General
    Last Post: 2008-06-04, 09:13 PM
  3. Replies: 0
    Last Post: 2007-05-22, 08:14 PM
  4. AutoCAD LT 2005 convert DWG files into JPG files?
    By dougm.79335 in forum AutoCAD LT - General
    Last Post: 2007-02-09, 01:28 PM
  5. Can you convert/export Revit files into pdf or plot files?
    By petercronin97702 in forum Revit Architecture - General
    Last Post: 2005-12-09, 01:47 AM
