Results 1 to 7 of 7
Thread: Using fields/diesel inside a block for "plot scale"
    2005-07
    Dublin, Ohio
    5
    Default Using fields/diesel inside a block for "plot scale"
    What is the best way to automate the "plot scale" inside a title block (block). I have tried to use fields, but they don't update automatically inside the block. I would like to use RText with diesel, but I can't figure out the code. I am using AutoCAD 2007.
    Any ideas? Thanks!
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    6,855
    Default Re: Using fields/diesel inside a block for "plot scale"
    If you use FIELDS within a block, make sure you place them within an Attribute. FIELDS within a block that are in TEXT / MTEXT do not update.
    2005-07
    Dublin, Ohio
    5
    When I used the field in an attribute it doesn't show up. I used the ATTDEF command to create the attribute. Am I missing something?
    2002-01
    jUSt Here (a lot)
    6,855
    Quote Originally Posted by RKirkbride
    It doesn't show up when you are defining the block? That is normal.
    Does the value update when you plot the drawing?
    All AUGI, all the time Mlabell's Avatar
    2004-12
    Toledo, OH
    513
    Here is a block of our sheet, which has the scale set to the pagesetup size, which is an attribute with a field. The bar scale is text with a field. Hopefully this helps.
    P.S. Opie do you know when they are going to re-open the dynamic block sharing thread again? I can't wait I have some new DB's I need to unleash to us civil's...
    2005-07
    Dublin, Ohio
    5
    It's working now. Looking at you example helped. One of my problems was that it had a duplicate tag defined (how stupid of me). Once I got rid of the duplicate it showed up properly. The key really was to use an attribute to hold the field.
    Thanks for the help.
    2006-09
    iran
    9
    Thumbs up Re: Using fields/diesel inside a block for "plot scale"
    Quote Originally Posted by marklabell
    HI.FOR YOU.
  1. Dynamic Block keeps "moving" when Annotative scale is changed
    By e3do in forum Dynamic Blocks - Technical
    Last Post: 2011-10-18, 08:03 PM
  2. Replies: 5
    Last Post: 2009-04-17, 10:10 AM
  3. HOW switch COMMAND "BLOCK" THE "Scale Uniformly"
    By viz_ken1030 in forum AutoLISP
    Last Post: 2006-11-17, 11:41 AM
  4. Where are "permissions" set for "Plot stamp" fields?
    By c.dale in forum AutoCAD General
    Last Post: 2006-02-22, 04:07 PM
  5. Rendering "outside" vs "inside" the Solids Model
    By rbdome in forum AutoCAD 3D (2006 or below)
    Last Post: 2005-04-26, 02:51 AM
