Results 1 to 10 of 10
Thread: Drawing existing plans
    2005-12
    Hartford, CT
    394
    Default Drawing existing plans
    Is there any way to set Revit so that all objects you draw / model are put on the existing phase. So far I have to draw everything on the new phase (the defualt) and then change the obejcts to the existing phase.
    I could stop if I wanted to bbeck's Avatar
    2016-01
    Sacramento, CA
    247
    Default Re: Drawing existing plans
    Set the properties of the View you're working in to Existing. After that, any modeling done in that view will be existing.
    I could stop if I wanted to kpaxton's Avatar
    2004-12
    Sarasota, FL
    493
    Tim,
    This setting is based upon what the setting is in the VIEW that you creat the elements in. What I will typically do is this:
    1) Duplicate your floor plan view - and call it 'First-Existing'.(or something).
    2) Then right-click and do a View Properties and change the Phase to 'Existing' (at the bottom).
    3) Then change Phase Filter to 'Show Complete'
    Items you create in this View, should carry the 'Existing' phase identity.
    Hope this helps,
    Kyle
    2005-09
    Perth Australia
    470
    Just to add on to Kyle.
    I find it helpful to fully dimension and lock the existing plan. Its existing so locking is good in this instance as there is no need to change its dimensions.
    I could stop if I wanted to mibzim's Avatar
    2005-06
    Brisbane, Australia
    260
    Would be good if there was a way to permanently lock / unlock existing phases.
    All AUGI, all the time Justin Marchiel's Avatar
    2004-07
    Penticton, B.C., Canada
    954
    as a bit of a work around you could pin the existing elements, and at least when you tried to do something to them you would get a warning.
    Justin
    2001-12
    1,714
    Quote Originally Posted by jmarchiel-barch
    Justin
    Seems to me that when you are in a view where Existing is Not current, you should not be able to move any thing that is Existing. Same is true for New Work. You want to move it, go to a view where New Work is current. This would stop a lot of the accidental stuff, and still leave things totally flexible, not over constrain the model with pins than then need unpinned when you really do need to move something, etc.
    Just a thought.
    Gordon
    2004-07
    954
    i agree. i was just offering a work around.
    Justin
    "Rock-n-Roll Architect" SCShell's Avatar
    2004-01
    Tucson, AZ
    1,272
    Hey there,
    I was told by the factory, a long time ago....pinning existing walls that should never move is better than locking it's dimension.
    For what it's worth,
    Steve
    2006-01
    4,516
    I can understand that, Shell... Locking its dim only means youre going to accidentally drag something else with it, instead of stopping you from moving it. We have some issues with this as well...
  1. 2013: Existing Plans
    By Sparky in forum Revit MEP - General
    Last Post: 2013-04-09, 09:56 PM
  2. Existing Vs New plans and equipment placement
    By Dinochrome in forum Revit - Platform
    Last Post: 2012-12-02, 10:34 PM
  3. Existing rooms & demolition plans
    By tim.101799 in forum Revit Architecture - General
    Last Post: 2008-05-15, 08:27 PM
  4. Existing-Demo Plans
    By harkeychad in forum Revit Architecture - General
    Last Post: 2007-10-26, 12:00 PM
  5. Elevation Tags in Existing Plans
    By nnguyen in forum Revit Architecture - General
    Last Post: 2006-09-19, 09:07 PM
