Thread: Architectural - Steel / Wood Studs (Metric & Imperial)
    Retired Forum Staff Rico's Avatar
    In the hospital cuz of my fever for more cowbell
    1,828
    Arrow Architectural - Steel / Wood Studs (Metric & Imperial)
    I thought I had posted these earlier, but to my surprise, I can't find them anymore ..... so I'm re-posting what I have.
    Steel Stud Dynamic Block - Imperial
    Steel Stud Dynamic Block - Metric
    Wood Stud Dynamic Block - imperial
    Wood Stud Block - Metric
    Let me know if there's any problems with these blocks
    [SIGPIC][/SIGPIC]
    Return of the Cowbell
    2005-12
    Hartford, CT
    394
    Default Re: Architectural - Steel / Wood Studs (Metric & Imperial)
    Quote Originally Posted by max.sabre
    Love the steel stud block. The only thing I would change (if I knew how) would be to add a visibilty parameter to switch between metal stud shapes and the corresponding metal tracks.
    1,828
    Quote Originally Posted by tim.101799
    You're not the first person to suggest that. it's on the to-do list here. I just haven't had the time. But maybe for X-mas ...
    [SIGPIC][/SIGPIC]
    2005-12
    Hartford, CT
    394
    I didn't feel like waiting till X-mas so I made my own.
    The attached block is that of a metal stud & track with a look up table for various standard sizes and a visibility parameter to switch between a stud shape and a track shape. Add / change the size in the look up table as you need.
    It is possibly to have certain sizes in the lookup table associated with a visibility state? I would love to add a 3rd visibility state in this block for metal hat furring and only have the hat furring sizes show when that visibility state it active.
    Tim Mailloux
    1,828
    I didn't feel like waiting till X-mas so I made my own ...
    (*snip*)
    Tim Mailloux
    Tim,
    I took the liberty of splitting your blocks up into their own separate drawing files.
    This way, it's easier for everyone to see the effort you put into your blocks and the diversity of your work.
    [SIGPIC][/SIGPIC]
  1. Architectural - Dynamic Locker System (Imperial & Metric)
    By Rico in forum Dynamic Blocks - Sharing
    Last Post: 2014-04-04, 01:17 PM
  2. Architectural - Dynamic Steel Deck (Imperial & Metric)
    Last Post: 2012-06-12, 12:29 AM
  3. Can't see studs using the wood framing tool
    By AP23 in forum Revit Architecture - General
    Last Post: 2010-10-28, 04:27 PM
  4. Metric to Imperial
    By ..shaner in forum Revit Architecture - General
    Last Post: 2009-08-21, 06:43 PM
  5. Metric vs Imperial
    By sbrown in forum Revit Architecture - General
    Last Post: 2004-01-27, 05:53 PM
