I need to get rid of this lines (see attached image)
Could they be the edge of a floor? Or are the doors inserted for some reason just a touch above the floor level?
What you're seeing is the edge of the floors. I usually use the linework tool and make the edges invisible lines.
By adjusting the bottom range of your view an inch or so above the floor level, you will not see the floor line. A good option if walls cover the floor except at door openings.
