Results 1 to 10 of 12
Thread: Copy & Paste problem - Pasted objects are offset?
    2004-07
    2
    Default Copy & Paste problem - Pasted objects are offset?
    AutoCAD 2006
    when using cntrl c then cntrl v, the pasted object is offset badly. Same for all objects-blocks, lines etc. Only in one drawing though....--copy with base point works fine. Any ideas?
    I could stop if I wanted to mom of 3's Avatar
    2004-07
    jUSt in the middle
    366
    1 members found this post helpful.
    Default Re: Copy & Paste problem - Pasted objects are offset?
    my guess is the drawings are different coordinates. I always use base point when I do copy-paste. that's my thoughts.........
    All AUGI, all the time Richard McDonald's Avatar
    2002-01
    At right angles to reality
    537
    When using ctrl c and then ctrl v my understanding is that ACAD give the items a arbitrary insertion point.
    If you need items in a certain place use ctrl+shift+c to copy with base point or if your drawings share the same co-ordinate system you can use the Edit>>Paste to original co-ordinates command.
    Hope this helps
    2004-07
    2
    does anyone know how to change the "arbitrary insertion point" that AutoCAD assigns to copied objects? What is it based on? Thanks!
    2004-07
    jUSt in the middle
    366
    I don't think you can. like Richard said (better than I did), it's probably because the drawings are different coordinates. if you copy by base point (0,0), then paste to that same point, your items should fall in the correct place that you want them to.
    13,620
    Hi
    Maybe look at the _.Base command.
    Have a good one, Mike
    2002-01
    537
    What will help is if I give the right info.
    Its ctrl+shift+c to copy with a base point
    All AUGI, all the time scott.wilcox's Avatar
    2015-11
    Edmonton, Alberta
    990
    Quote Originally Posted by jrisk
    I think the arbitrary point is somewhere near the lower left corner of the selected geometry.
    I have redefined crtl+shift+V to paste to original coordinates, and assigned crtl+shift+B to paste as block. ctrl+C then ctrl+shift+V does it.
    2005-06
    in the upper right corner
    3,031
    Thumbs up Re: Copy & Paste problem - Pasted objects are offset?
    Quote Originally Posted by scott.wilcox
    I use "copy with basepoint" and "paste to original coordinates" all the time. I've created aliases for 'copybase' and 'pasteorg' in my pgp file [see below].
    CB, *COPYBASE
    PO, *PASTEORIG
    I usually use these like:
    "cb" (you pick a basepoint) then "ctr+v" (you pick the insertion point).
    or
    "ctrl+c" (you simply select you objects) then "po" paste to original coordinates.
    It's very important that your ucs is in the same coordinate in both locations or it won't work.
    I always have my "uscicon" "on" just to be sure.
    good luck
    Ted
    ____________________________________________________________________ ________________
    Windows 7 Professional
    AutoCAD 2017 - REVIT 2017 - Inventor Professional 2015 (when I can)
    2002-01
    Had the same issue and it was a USC issue. Did a 3d view top and now works fine...
  1. 2012: Auto CAD Copy/Paste Problem
    By eldosrajan401784 in forum AutoCAD General
    Last Post: 2013-03-08, 04:07 PM
  2. Copy/Paste Objects to All Layout Tabs
    By acadwishlist in forum AutoCAD Wish List
    Last Post: 2011-11-23, 02:00 AM
  3. copy and paste problem on sheets
    By iankids in forum Revit Architecture - General
    Last Post: 2008-10-22, 06:43 AM
  4. AutoCAD 2002 unable to Copy and Paste Objects
    By chrisr in forum AutoCAD General
    Last Post: 2006-08-29, 11:19 PM
  5. Replies: 25
    Last Post: 2006-02-21, 06:26 PM
