Thread: Schematic Design, Area Plans, and Floor Plans
    Member bleonard's Avatar
    2005-03
    San Diego, CA
    33
    Cool Schematic Design, Area Plans, and Floor Plans
    Hey Folks. I've been thinking through the Schematic Design Process in REVIT and have been particularly excited about the power of the key schedules for ROOMS. I've found that we can generate our programs from client discussions with the use of the room key, and then quickly start creating scheduleable options by assiging modeled rooms to the key values. Our office tends to have some highly complex programs, so it's exciting to be able to start managing that information in schedule form in Revit before we even start the process of design.
    However, I've seen several posts about area plans being used in a similar way, where people suggest using them for initial schematic design. The disadvantage that I see is that areas are independent of Rooms. Meaning that any parametric information one assigns to an AREA cannot be assigned to a corresponding ROOM.
    Ideally, we would be able to generate colored area plans whose color fill schemes extracted ROOM information. I was thoroughly disappointed that departments or other parameters of rooms could not be quickly used to generate an area plan. I see the point of making them independent, however, it would be really nice if they could communicate at some point with each other.
    In the end, I think we would rather have the ability to use our program information in ROOMS from the beinning through the end, rather than have to duplicate information by switching from AREA plans to normal FLOOR plans.
    Anybody else have any thoughts on this subject?
    2002-02
    St. Louis, MO
    4,695
    Default Re: Schematic Design, Area Plans, and Floor Plans
    Rooms are always net. Areas can be gross. Rooms cannot overlap. Areas can be sliced and diced just about anyway you want using several different area plans.
  1. Copy dependent floor-plans to ceiling-plans.
    By thomas.163390 in forum Revit Architecture - General
    Last Post: 2010-07-19, 01:59 PM
  2. area plans and design options
    By jacek.brzezowski in forum Revit - Platform
    Last Post: 2010-03-30, 11:47 PM
  3. Detail lines Floor Plans and Ceiling Plans
    By techsupport.161645 in forum Revit Architecture - General
    Last Post: 2010-02-05, 06:57 PM
  4. Level tied to Ceiling plans instead of Floor Plans
    By Andre Baros in forum Revit Architecture - General
    Last Post: 2006-01-27, 01:06 AM
  5. Allow underlays of Reflected Ceiling plans in Floor plans
    By juggergnat in forum Revit Architecture - Wish List
    Last Post: 2004-08-29, 06:49 PM
