Thread: MvParts in ABS2007
    2006-12
    52
    Default MvParts
    If I have an MvPart in a drawing, but it's not a part of my catalogue, is it possible to add it to the catalogue without re-drawing a 3D block and using the content editor?
    2003-10
    San Francisco CA
    1,190
    Default Re: MvParts in ABS2007
    Hi Thomas,
    I was just looking at some old posts and saw that you hadn't received any responses to this one. If I understand your question correctly I think the answer to your question is yes.
    What you would need to do is drag the MvPart onto your palette (or create a temporary palette and drag it to it) and then open your content browser, (right-click at the top and select always on top) navigate to the catalog you would like to add the tool, and drag and drop the MvPart from the palette to your catalog.
    If I've completely missed what you were trying to do post back and I'll try again.
    Scott Telthorst
    Quality Control Manager
    Helix Electric, Inc.
    www.helixelectric.com
  1. AMEP2008 vs. ABS2007.1
    By finney13 in forum AMEP General
    Last Post: 2007-12-10, 06:34 PM
  2. Formula Help in ABS2007.1
    By stelthorst in forum Style Management
    Last Post: 2007-04-16, 11:22 PM
  3. ABS2007 Property set help
    Last Post: 2007-03-27, 12:11 PM
  4. DST files in ABS2007
    By finney13 in forum Project Navigator
    Last Post: 2007-02-26, 05:18 PM
  5. Haloed lines and MvParts in ABS2007
    By ordengate in forum Display Management
    Last Post: 2007-01-04, 11:13 AM
