Results 1 to 9 of 9
Thread: Trouble plotting aerial photo in Black and White
    2004-07
    Question Trouble plotting aerial photo in Black and White
    I am having trouble plotting plan sheets with a color aerial photo to black and white. We are using an HP 1050C plotter, and have it set to grayscale, but the photo keeps coming out in full color, while the linework does come out in black and white. The image we are working with is a huge SID file. Does anyone know how to get the photo to plot in black and white?
    2001-10
    Arizona
    2,337
    Default Re: Trouble plotting aerial photo in Black and White
    Yes edit or create a NEW CTB that is set to greyscale,
    and or alter the printer properties by toggleing the
    Properties button during a page setup, and go to the
    graphics option and set it to greyscale there, thus
    making autocad believe that the printer is only cabable of
    plotting in black and white.
    Be your Best,
    Michael Farrell
    www.primeservicesglobal.com
    2001-03
    13,499
    Hi
    Check out the following Technical Documents on the Autodesk web site under the Knowledge Base section -
    ID: TS38402 - Monochrome and grayscale plot style tables do not affect raster image output
    ID: TS31570 - Plot drawings in black and white
    ID: TS18255 - Plot drawings in black and white
    Have a good one, Mike
    I could stop if I wanted to mom of 3's Avatar
    2004-07
    jUSt in the middle
    366
    ok, so if I don't have access to change the pen tables, nor do we have the monochrome pen table, nor do we have the greyscale option under the graphics in the page set ups, what other suggestions are there? I've tried the grayscale in both the plot styles & on the plotter itself, but it continues to plot in color.
    2001-10
    Arizona
    2,337
    You will have to acquire access to edit the CTB, as even the support
    articles posted by the esteemed Mr. Perry will require you to perform
    the exact same functions as in my post.
    Be your Best,
    Michael Farrell
    2004-07
    jUSt in the middle
    366
    thank you! we will work on that access in hopes that we can get these plotted!
    100 Club cholmes's Avatar
    2003-02
    Omaha, NE
    198
    Ok, so in the .CTB file, we have all of the colors set to black. The greyscale for each color is turned off. Do all of these need to be turned on? How will this effect other plots using this .ctb file? We would rather not have multiple .ctb's, but if we need to we can.
    Chris
    2001-10
    Arizona
    2,337
    Chris
    You will want grey scale enabled.
    For most costomer sites I like to
    set them up one CTB for color
    and line weight, and then copy it
    and set it to black and white.
    Then for any speacial plotting needs
    that CTB will be saved with the drawing
    in the project folder. This will keep your
    plotting options much cleaner.
    Be your Best,
    Michael Farrell
    2003-02
    Omaha, NE
    198
    Alright, I made a copy of the .ctb and set all of the colors to "use object color" and then turned on the check box for all of them for grayscale.
    Tried a test plot and the previes still shows the raster in color, and all of the other linework in the drawing is not right, as it is now grayscaled.
    This has been a pretty confusing situation, and it doesn't seem to make sense to me. I understand the concept of changing the .ctb to grayscale, but would this only affect actual autocad entities, such as line work? The raster image itself doesn't inherit any kind of pen settings, except maybe the frame. And if you do change all the colors to grayscale, then that affects all the linework in the drawing, which is not what we want to happen.
    The setting on the plotter itself is also set to grayscale, which make it even more confusing.
    Thanks!
    Chris
  1. KIP 3000: Wipeouts plotting as black and white bars
    By MaryS in forum AutoCAD Plotting
    Last Post: 2011-02-01, 06:17 PM
  2. plotting Color jpeg files black and white
    By dontejalynx in forum AutoCAD General
    Last Post: 2010-10-07, 08:39 PM
  3. Aerial Photo
    By chet.smith in forum Raster Design - General
    Last Post: 2008-07-29, 02:26 PM
  4. Plotting black and white
    By erikbjur in forum Revit - Plotting/Printing/Exporting
    Last Post: 2006-05-17, 02:56 AM
  5. Plotting issues white letters on black bgrd
    By jarod.tulanowski in forum Revit Architecture - General
    Last Post: 2005-02-24, 06:52 PM
