Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Find and Replace text in multiple drawings
  1. #11
    2005-12
    San Luis Obispo, CA
    285
    Default Re: Find and Replace text in multiple drawings
    Quote Originally Posted by eugene_k View Post
    I believe those people capable of doing this level of lisp programing could do much better job by creating a universal code for batch processing various lisp files on multiple drawings. Instead of solving just one problem of text replacement, we couls just start this batch engine program, select the files to be processed and then select a lisp to run! It could be lisp for text replacement or for anything else - you name it. This is where the real power is. Maybe Autodesk should provide this sort of engine instead of its ScriptPro...
    There is no good tool availbale at the moment. If anybody ever find something good, please let me know!
    not available for free, but available none the less and has been for some years
  2. #12
    Certifiable AUGI Addict
    2015-11
    Jo'burg SA
    4,512
    Well, having it run through a SCR file is really not dificult. E.g. make your SCR file as so:
    (load "FileName.LSP")
    (function_name arg1 arg2)
    CommandName Input1 Input2
    So you can have this working through ScriptPro, or if you're on 64bit use AutoScript.
    And BTW, there is already something which simply runs a LSP file on multiple DWG's. It basically just creates the SCR file and then runs it. It's called BatchLisp.
  3. #13
    2010-11
    I get an error that says
    VLA-OBJECT nil
  4. #14
    2010-02
    hi!
    I'm using AutoCAD 2009, and i've received de error message:"; error: no function definition: VLAX-GET-ACAD-OBJECT"
    Can u please help?
  5. #15
    2009-03
    London, England
    304
    Quote Originally Posted by carlosmanteigas View Post
    Can u please help?
    Add:
    (vl-load-com)
    On a new line at the end of the file.
  6. #16
    2010-04
    when i add the (vl-load-com) i get a new error:
    Loaded new command Reid.
    [c]2004 Andrzej Gumula.
    Command: reid
    ; error: Automation Error. Problem in loading application
    Using Acad 2012
    (this is version 18.2 so i am not sure about the version part of the LSP)
  7. #17
    2010-09
    24
    Quote Originally Posted by jsowinski View Post
    Here is a routine that came from Cadalyst Tips (author - Andrzej Gumula). This is a great tool that works fast. If you encounter an error while running you will want to check the part of the code that looks for (getvar "AcadVer"). "ObjectDBX.AxDbDocument.17" You may have to update the number in the lisp to the version of AutoCAD you're using.
    Hi to all,
    I am running the routine and displays the following message:
    Command: REID
    Looking for text to replace. Please wait...
    Cannot find in C:\_TEST\TEST-01.dwg. Probably drawing is open now.
    Cannot find in C:\_TEST\TEST-02.dwg. Probably drawing is open now.
    Cannot find in C:\_TEST\TEST-03.dwg. Probably drawing is open now.
    ERROR: bad argument type: VLA-OBJECT nil
    Command:
    But these drawings are not open.
    Could anyone help me with this?
  8. #18
    2002-08
    231
    If you want try this...
    You must save the lisp file "my_text_replace.lsp" in path (or create it) for AutoCad.
    And after in new drawing load the code next
    (defun c:make_script_for_text_replace ( / prefix file_scr old_str new_str)
    	(setq
    		prefix (strcat (vl-filename-directory (getfiled "Select a drawing file for folder target" "" "dwg" 16)) "\\")
    		file_scr (open (strcat prefix "job_on_folder.scr") "w")
    	(princ "\nBe careful with the case of character!")
    	(setq
    		old_str (getstring T "\nOld chain of character to replace: ")
    		new_str (getstring T "\nBy new chain of character: ")
    	(foreach dwg (vl-directory-files prefix "*.dwg" 1)
    		(write-line "_.open" file_scr)
    		(write-line (strcat "\"" prefix dwg "\"") file_scr)
    		(write-line "(load\"my_text_replace\")" file_scr)
    		(write-line (strcat "(my_text_replace \"" new_str "\" \"" old_str "\")") file_scr)
    		(write-line "_.qsave" file_scr)
    		(write-line "_.close" file_scr)
    	(close file_scr)
    	(princ (strcat "\nYou can run the SCRIPT :" prefix "job_on_folder.scr"))
    	(prin1)
  9. #19
    2010-09
    24
    Quote Originally Posted by Bruno.Valsecchi View Post
    	(setq
    	(setq
    	(close file_scr)
    	(prin1)
    Thanks Bruno.
    This routine worked for me.
  1. Find and Replace for Multiple Drawings
    Last Post: 2015-10-07, 11:07 AM
  2. 2011: Replace block in multiple drawings
    By swapr78 in forum ACA General
    Last Post: 2013-09-05, 04:37 PM
  3. Text find and replace
    Last Post: 2012-11-13, 03:48 PM
  4. Text Find and Replace
    By madyb in forum Revit Structure - General
    Last Post: 2009-10-29, 07:40 PM
  5. Multiple Find and Replace
    By cjshaw in forum AutoCAD LT - General
    Last Post: 2007-02-05, 08:46 PM
