Thread: SS multiple publishing
    2001-12
    Transylvania
    4
    Default SS multiple publishing
    I have Sheet Set made of layouts in different drawing files, how can I publish it many times in one step. Where can I specify the number of copyes I want the Sheet Set to be published?
    Best regards,
    v.
    2001-12
    St. Louis
    5,408
    Talking Re: SS multiple publishing
    Unfortunately, you cannot do this yet. That is a sad oversight on the part of autodesk, that I hope will be remedied in the next version.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2016-01
    Default Re: SS multiple publishing
    When you right click in the sheet set to publish just select Publish Dialog Box. There is a option for number of copies.
    2001-12
    St. Louis
    5,408
    Quote Originally Posted by pschlickenmaier
    Never explored much in there. Personally, I use 'publish using page setup override', and I think page setup override should be available in the publish dialog box.
    I have no idea how I last printed something, to what plotter or size, it should be easy to override.
    Thanks for the info on the dialog box, very cool.
    Melanie Stone
    @MistresDorkness
    Technical Editor
  1. publishing from pn
    By earnold in forum Project Navigator
    Last Post: 2010-03-02, 01:02 AM
  2. AutoCAD 2009 multiple copies not publishing correctly
    By litchfieldl in forum AutoCAD Plotting
    Last Post: 2008-07-14, 02:40 PM
  3. publishing can do it
    By sherflor in forum CAD Management - General
    Last Post: 2008-05-08, 08:29 PM
  4. DWF Publishing
    By andre.gawlik in forum Revit - Plotting/Printing/Exporting
    Last Post: 2007-04-27, 05:34 AM
  5. Publishing
    By BCrouse in forum AutoCAD Wish List
    Last Post: 2005-01-20, 10:36 PM
